HPE HP 2920-48G Switch
Installation required? Contact us today!
Quicklinx: C8YZWS00 Mfr#: J9728A
The HP 2920 Switch Series provides security, scalability and ease of use for enterprise edge, SMB and branch office access layer deployments. A powerful HP Networking ASIC delivers low latency, more packet buffering, and adaptive power consumption to this robust Basic Layer 3 switch that supports modular stacking, 10GbE, RIP routing, PoE+, ACLs, sFlow and IPv6. The HP 2920 Switch Series can be managed with the optional HP Intelligent Management Center (IMC) software for a single view of your entire network and is ready for the Software-defined Network (SDN) with OpenFlow support.
  • Flexible and Scalable Access Layer Switches
    The Aruba 2920 Switch Series provides security, scalability, and ease of use for enterprise edge, SMB, and branch office networks.Cost-effective, pay-as-you-grow modular stacking support for up to four 10GBASE-T (or SFP+) links and upgradeable power supplies allow your network to quickly scale when needed.Robust Layer 3 feature set includes static and RIP routing, Access OSPF routing, ACLs, sFlow, IPv6, and requires no software licensing.Designed with a powerful ProVision ASIC and support for OpenFlow, the Aruba 2920 is ready for the software defined network with REST APIs and OpenFlow support.Optimized for the digital workplace with unified management tools such as Aruba ClearPass Policy Manager, Aruba Airwave and Aruba Central. Provides optimal configuration automatically when connected to Aruba access points for PoE priority, VLAN configuration, and rogue AP containment.
  • High Performance and Power at the Edge
    The Aruba 2920 Switch Series is designed with a powerful ProVision ASIC, providing low latency, increased packet buffering, and adaptive power consumption so the network can support the media-rich, bandwidth-intensive applications your business demands.Increase performance with selectable queue configurations and associated memory buffering that meet your network application requirements.With up to 740 W of internal PoE+ power, the Aruba 2920 Switch Series can easily scale to 1440 Watts with a simple connection to an external power supply (EPS) or redundant power supply (RPS).Plug and play stacking with automated failover enhances network resiliency and RPS support delivers power redundancy.Efficient 80 PLUS Silver Grade Power Supplies, Energy Efficient Ethernet, and LLDP-MED conserve energy resources. Removable power supplies reduce downtime during upgrades and servicing.
  • Security and Quality of Service (QoS)You Can Rely on
    The Aruba 2920 Switch Series includes security and quality of services features to build a network that meets ever-changing corporate policies and compliances and help protect your data from both inside and outside attacks.Flexible authentication options include standards based security protocols such as 802.1X, and MAC and Web for greater, policy-driven application security.Powerful, multilevel-access security controls include source-port filtering, RADIUS/TACACS+, SSL, Port Security, and MAC address lockout.Tunneled node to transport network traffic on a per-port basis to Aruba controller with authentication and network policies applied and enforced at the controller.
  • Simplify with Integrated Wired/Wireless Management
    The Aruba 2920 Switch Series supports Aruba ClearPass Policy Manager for unified and consistent policy between wired and wireless users and simplifies implementation and management of guest login, user onboarding, network access, security, QoS, and other network policies.Supports Aruba Airwave to provide common platform for Zero-Touch Provisioning management, and monitoring for wired and wireless network devices.Cloud-based management supported by Aruba Central.RMON and sFlow provide advanced monitoring and reporting capabilities for statistics, history, alarms, and events.Out-of-band Ethernet management port keeps management traffic segmented from your network data traffic.
HPE Aruba 2920-48G - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
44 x 10/100/1000 + 4 x combo Gigabit SFP
Performance
Throughput: 130.9 Mpps , Switching capacity: 176 Gbps
IPv4 routing table entries: 2048 , IPv6 routing table entries: 256
MAC Address Table Size
16000 entries
Routing Protocol
RIP, IGMP, static IP routing, MLD
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SMON, SSH, SSH-2, CLI
Flow control, BOOTP support, ARP support, DoS attack prevention, IPv6 support, half duplex mode, full duplex mode, sFlow, RADIUS support, Uni-Directional Link Detection (UDLD), Link Aggregation Control Protocol (LACP), Energy Efficient Ethernet, Class of Service (CoS)
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1s, IEEE 802.1v, IEEE 802.3az, IEEE 802.1AX
44.25 cm x 33.6 cm x 4.45 cm
5.42 kg
Pricing Type
Factory integrated
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
16000 entries
Routing Protocol
Encryption Algorithm
SSL, TLS
Authentication Method
RADIUS, PAP, CHAP, TACACS, TACACS+, Extensible Authentication Protocol (EAP)
1 x ARM ARM1176: 625 MHz
RAM
512 MB SDRAM
Flash Memory
1 GB
48 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 4 x SFP (mini-GBIC) , 1 x management (RS-232) RJ-45 , 1 x management (mini-USB) Type B , Management: 1 x 4 pin USB Type A
Expansion Slots
2 (total) / 2 (free) x Expansion Slot , 1 (total) / 1 (free) x Stacking Module
Internal power supply
80 PLUS Certification
80 PLUS Silver
C-Tick, GOST, CISPR 24, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, EN55024, EN55022 Class A, FCC Part 15 B, ICES-003 Class A, RoHS, EN 60950-1, IEC 60825-1, EN 60825-1, IEC 60950-1 Second Edition, VCCI Class A
Pricing Type
Factory integrated
44.25 cm
33.6 cm
4.45 cm
5.42 kg
55 °C
15 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
C8YZ C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
C8YZ C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.23
C8YZ C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.98
C8YZ C2G 2m Cat6a Shielded Patch - Blue In Stock £7.38
