The HPE 2620 Switch Series provides cost-effectiveness, flexibility, and ease of use for enterprise edge, SMB, and branch office access layer deployments. This Fast Ethernet switch has a robust Basic Layer 3 feature set with static and RIP routing, PoE+, ACLs, sFlow, IPv6, and requires no software licensing. The HPE 2620 Switch Series is easy to use and deploy, and delivers consistent wired/wireless user experience with unified management tools such as ClearPass Policy Manager and Airwave Network Management.
Flexible, Simple and Cost-effective Fast Ethernet Switches
The Aruba 2620 Switch Series provides cost-effectiveness, flexibility, and ease of use for enterprise edge, SMB, and branch office access layer deployments.Cost-effective Fast Ethernet switch with four Gigabit Ethernet uplinks (two copper and two SFP) and support for external and redundant power supplies for improved network resiliency and quickly scaling of PoE+ devices.Robust Basic Layer 3 feature set includes static and RIP routing, PoE+, ACLs, sFlow, IPv6, and requires no software licensing. -
Power at the Edge
The Aruba 2620 Switch Series is designed with up to 370 W of internal PoE+ power and easily scales to 740 Watts with simple connection to EPS/RPS. A model with 128 W is ideal when you only need to power several PoE+ devices.Optional redundant power with external RPS/EPS enhances network resiliency. Highly rated, 80 PLUS Silver Grade Power Supplies on the 2620-24-PoE+ and 2620-48-PoE+ switches conserve energy resources.Increase performance with selectable queue configurations and associated memory buffering that meet your network application performance requirements. -
Security and Quality of Service (QoS) You Can Rely on
The Aruba 2620 Switch Series includes security and (QoS) features to build a network that meets ever-changing corporate policies and compliances and helps protect your data from both inside and outside attacks.The Aruba 2620 Switch Series supports flexible authentication options include standards based security protocols such Local MAC, 802.1X, and MAC and Web for greater, policy-driven application security.Traffic prioritization (IEEE 802.1p) allows real-time traffic classification into eight priority levels that are mapped to eight queues.Powerful multilevel-access security controls include source-port filtering, RADIUS/TACACS+, SSL, Port Security, and MAC address lockout.Defend your IPv6 network with DHCPv6 Protection. -
Single View of the Network
The Aruba 2620 Switch Series supports Aruba ClearPass Policy Manager for unified and consistent policy between wired and wireless users and simplifies implementation and management of guest login, user onboarding, network access, security, QoS, and other network policies.Supports Aruba Airwave to provide common platform for Zero-Touch Provisioning management, and monitoring for wired and wireless network devices.RMON and sFlow provide advanced monitoring and reporting capabilities for statistics, history, alarms, and events.TR-069 delivers zero touch deployment for devices with dynamic IP addresses and on private networks.
- HPE Aruba 2620-24-PoE+ - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - L4 - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- 24 x 10/100 (PoE) + 2 x 10/100/1000 + 2 x SFP
- Power Over Ethernet (PoE)
- PoE
- Performance
- Routing/switching capacity: 12.8 Gbps , Throughput: up to 9.5 Mpps
- MAC Address Table Size
- 16000 entries
- Jumbo Frame Support
- 9220 bytes
- Routing Protocol
- RIP-1, RIP-2, IGMPv3, MLDv2, MLD
- Remote Management Protocol
- SNMP 1, RMON 2, RMON, Telnet, SNMP 3, SNMP 2c, HTTPS, TFTP, SMON
- Flow control, auto-sensing per device, DHCP support, power over Ethernet (PoE), ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, IPv6 support, half duplex mode, full duplex mode, sFlow, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping, PoE+, STP Root Guard, LLDP support, MAC address lockout, dynamic ARP protection, DHCP protection, per-port broadcast throttling
- IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1v, IEEE 802.1ab (LLDP), IEEE 802.3at
- Power
- AC 120/230 V (50/60 Hz)
- 44.3 cm x 36.8 cm x 4.4 cm
- 4.8 kg
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- PoE
- Performance
- 16000 entries
- 9220 bytes
- Routing Protocol
- Encryption Algorithm
- SSL
- Authentication Method
- RADIUS, TACACS+, Secure Shell v.2 (SSH2)
- Processor
- 1 x Freescale MPC8313: 400 MHz
- RAM
- 512 MB
- Flash Memory
- 512 MB
- 24 x 10Base-T/100Base-TX - RJ-45 PoE , 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x console RJ-45 management
- Power Device
- External power adapter
- Voltage Required
- Rack Mounting Kit
- Included
- FCC Class A certified, CISPR 22 Class A, CISPR 24, EN 60950, EN 61000-3-2, EN55022, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, VCCI Class A ITE, IEC 60950, EN 61000-3-3, EN55024, UL 60950, CSA 22.2 No. 60950, EN 60825
- 44.3 cm
- 36.8 cm
- 4.4 cm
- 4.8 kg
- 0 °C
- 55 °C
- 15 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 15 - 90% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
