HP Switch Modules are components that you can add to an HP Switch to provide a variety of network connectivity options. HP Switch Module's ports are all configured to be ready for network operation as soon as a viable network cable is connected. Default configuration is applied to the module when the switch is powered on and the module passes self test; this default configuration works well for most network installations. LEDs provide information on the link status, network activity, connection bandwidth, and communication mode (half or full duplex). "Hot swap" operation is supported, so you can add a module or replace a module without having to shut down the switch (changing the module type in a given slot does require a switch reset).
- HPE 10/100 PoE+ zl - expansion module - 10/100 Ethernet x 24
- Expansion module
- Form Factor
- Plug-in module
- Ports
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX
- Data Link Protocol
- 10Mb LAN, 100Mb LAN
- Data Transfer Rate
- 100 Mbps
- Designed For
- HP Switch 5406zl-48, Switch 5412, Switch 5412zl-96; HPE 8206, 8206-44G-PoE+/2XG-SFP+ v2, 8212, 8212-92G-PoE+/2XG-SFP+ v2, Switch 5406, Switch 8212; HPE Aruba 5406, 5406-44, 5406-44G-PoE+-2XG v2, 5406-48, 5412, 5412-92, 5412-92G-PoE+-2XG v2, 5412-92G-PoE+-4G v2, 5412-96
- Expansion module
- Form Factor
- Plug-in module
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- Ethernet, Fast Ethernet
- 100 Mbps
- Power over Ethernet (PoE)
- 24 x 100Base-TX (PoE) - RJ-45
- Compatible Slots
- 1 x Expansion Slot
- Designed For
- HP Switch 5406zl-48G Intelligent Edge, Switch 5406zl-48G-PoE+, Switch 5412zl Intelligent Edge, Switch 5412zl-96G Intelligent Edge, Switch 5412zl-96G-PoE+ , HPE 8206 zl Switch, 8206-44G-PoE+/2XG-SFP+ v2 zl Switch, 8212 zl Switch, 8212-92G-PoE+/2XG-SFP+ v2 zl Switch, Switch 5406zl Intelligent Edge, Switch 8212zl , HPE Aruba 5406 zl, 5406-44G-PoE+/4SFP Rack Shippable zl Switch, 5406-44G-PoE+/4SFP zl, 5406-44G-PoE+-2XG v2 zl, 5406-48G Rack Shippable zl, 5406-48G zl, 5412 zl, 5412-92G-PoE+/4SFP Rack Shippable zl, 5412-92G-PoE+/4SFP zl, 5412-92G-PoE+-2XG v2 zl, 5412-92G-PoE+-4G v2 zl, 5412-96G zl
