HPE HP 1TB 7200rpm SATA-600 32MB 3.5" Internal Hard Drive
Quicklinx: 9MZ7WS00 Mfr#: LQ037AA
SATA 7200 rpm drives are our standard high bandwidth hard drive storage options; most workstation models are also available with high performance 10K rpm rotation speeds. Storage capabilities range up to a massive 2.0 TB.
HP - hard drive - 1 TB - SATA 6Gb/s
Hard drive - internal
1 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
32 MB
Spindle Speed
7200 rpm
8.89 cm x 10.17 cm x 2.54 cm
Workstation Z1 G5 Entry, Z2 G4, Z2 G5, Z2 G8, Z2 G9 (SFF, tower), z210, Z220, Z230, Z4 G4, Z420, Z6 G4, Z620, Z640 (3.5"), Z8 G4, Z820
1 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
32 MB
8.89 cm
10.17 cm
2.54 cm
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" x 1/3H
Shipping Width
23.2 cm
Shipping Depth
18.4 cm
Shipping Height
9.5 cm
HP Workstation Z1 G5 Entry, Z2 G4, Z2 G5, Z2 G8, Z2 G9 (SFF, tower), z210, Z220, Z230, Z4 G4, Z420, Z6 G4, Z620, Z640 (3.5"), Z8 G4, Z820
