Product
HPE HP 1TB 12G 7.2k rpm HPL SAS SFF (2.5in) Smart Carrier 512e
Quicklinx: C6K4WS00 Mfr#: 765464-B21
Form Factor: 2.5" SFF
Type: Hard drive
Interface Type: SAS
Capacity: 1TB, 1TB
Spin Speed (rpm): 7200rpm
£199.68 ex VAT
£239.61 inc VAT
Do your servers need high-performance SAS disk drives for both your mission-critical and storage driven applications? HPE Server SAS Hard Drives for enterprise and midline applications deliver high-performance solutions for hosting high transaction based applications. They are available in HPE Smart Carrier, HPE Standard Hot Plug Carrier and HPE Non-hot Plug Carrier. HPE Server SAS Hard Drives are available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) and come in a variety of capacity points to meet a wide range of requirements supporting enterprise and midline applications. The SAS interface was specifically engineered to deliver high availability where enterprise-class data storage, performance, reliability and data integrity are crucial.
Technical features
Capacity 1TB
Interface SAS
HD type Hot plug
Connectivity Dual-Port
Form factor SFF
What's included
(1) HP 1TB 12G SAS 7.2K rpm SFF (2.5-inch) SC 512e
Product differentiator
HP 1TB 12G SAS 7.2K 2.5in SC 512e HDD
HPE - hard drive - 1 TB - SAS 12Gb/s
Hard drive - hot-swap
1 TB
2.5" SFF
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Spindle Speed
7200 rpm
Advanced format 512e
7.57 cm x 11.87 cm x 1.56 cm
1 year warranty
Bundled with
HP SmartDrive carrier
ProLiant BL460c Gen10, BL660c Gen9, DL180 Gen9, DL20 Gen9, DL360 Gen10, DL360p Gen8, DL380 Gen10, DL385 Gen10, DL388 Gen9, DL560 Gen10, DL560 Gen9, DL580 Gen10, DL580 Gen9, ML110 Gen10, ML110 Gen9, ML30 Gen9, ML350 Gen10, XL190r Gen10, XL230a Gen9, XL230k Gen10, XL250a Gen9, XL450 Gen10; StoreEasy 1850; Synergy 480 Gen10
1 TB
2.5" SFF
SAS 12Gb/s
Bytes per Sector
512
7.57 cm
11.87 cm
1.56 cm
Bundled with
Performance
Drive Transfer Rate
1.2 GBps (external)
Seek Time
8.7 ms (average) / 17.16 ms (max)
Track-to-Track Seek Time
0.7 ms
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SAS 12 Gb/s
Compatible Bay
2.5" SFF
Limited warranty - 1 year
10 °C
35 °C
HPE ProLiant BL460c Gen10 (2.5"), DL20 Gen9 (2.5"), DL20 Gen9 Entry (2.5"), DL20 Gen9 Performance (2.5"), DL20 Gen9 Solution (2.5"), DL360 Gen10 (2.5"), DL360 Gen10 Base (2.5"), DL360 Gen10 Entry (2.5"), DL360 Gen10 High Performance (2.5"), DL360 Gen10 Low (2.5"), DL360 Gen10 Performance (2.5"), DL360 Gen10 Solution (2.5"), DL380 Gen10 (2.5"), DL380 Gen10 Base (2.5"), DL380 Gen10 Entry (2.5"), DL380 Gen10 High Performance (2.5"), DL380 Gen10 Performance (2.5"), DL380 Gen10 Solution (2.5"), DL385 Gen10 (2.5"), DL385 Gen10 Base (2.5"), DL385 Gen10 Entry (2.5"), DL385 Gen10 High-Performance (2.5"), DL385 Gen10 Performance (2.5"), DL385 Gen10 Solution (2.5"), DL388 Gen9 (2.5"), DL388 Gen9 Base (2.5"), DL560 Gen10 (2.5"), DL560 Gen10 Base (2.5"), DL560 Gen10 Entry (2.5"), DL560 Gen10 Performance (2.5"), DL560 Gen9 (2.5"), DL560 Gen9 Base (2.5"), DL560 Gen9 Entry (2.5"), DL560 Gen9 Performance (2.5"), DL580 Gen10 (2.5"), DL580 Gen10 Base (2.5"), DL580 Gen10 Entry (2.5"), DL580 Gen10 Performance (2.5"), DL580 Gen9 SAP HANA Scale-up Base Configuration (2.5"), ML110 Gen10 (2.5"), ML110 Gen10 Performance (2.5"), ML110 Gen10 Solution (2.5"), ML30 Gen9 (2.5"), ML30 Gen9 Base (2.5"), ML30 Gen9 Entry (2.5"), ML30 Gen9 Performance (2.5"), ML30 Gen9 Solution (2.5"), ML350 Gen10 (2.5"), ML350 Gen10 Base (2.5"), ML350 Gen10 Entry (2.5"), ML350 Gen10 Performance (2.5"), ML350 Gen10 Solution (2.5"), ML350 Gen10 Sub-Entry (2.5"), XL190r Gen10 (2.5"), XL230a Gen9 Compute Tray (2.5"), XL230a Gen9 Compute Tray (12G) (2.5"), XL230a Gen9 Compute Tray (6G) (2.5"), XL230k Gen10 Compute Tray (2.5"), XL250a Gen9 Accelerator Tray (2.5"), XL450 Gen10 (2.5") , HPE Synergy 480 Gen10 Base Compute Module (2.5"), 480 Gen10 Entry Compute Module (2.5"), 480 Gen10 Performance Compute Module (2.5"), 480 Gen10 Premium Backplane Compute Module (2.5"), 480 Gen10 Standard BackPlane Compute Module (2.5"), 480 Gen10 w/o Drives Compute Module (2.5")
Type: Hard drive
Interface Type: SAS
Capacity: 1TB
Capacity: 1TB
Brand: HPE
Price Range Ex VAT: 150 - 300
