The HPE 1920 Switch Series, part of the HPE OfficeConnect portfolio, is designed for smaller organizations dealing with bandwidth-demanding applications. The switches are ideal for environments that require advanced features for granular control and where smart-managed flexibility is a must for easy network configuration and management. The switches deliver advanced smart-managed fixed configuration Gigabit switches that build on the marketing-leading price/performance of the HPE 1910 Switch Series. They feature a new 48-port PoE+ model, IPv6 support and advanced silicon technology.
- HPE 1920-8G - switch - 8 ports - Managed - rack-mountable
- Switch - 8 ports - L3 - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000 + 2 x Gigabit SFP
- Performance
- Throughput: 14.8 Mpps , Routing/switching capacity: 20 Gbps
- Capacity
- IPv4 routing table entries: 32 , IPv6 routing table entries: 32
- MAC Address Table Size
- 8192 entries
- Jumbo Frame Support
- 10KB
- Routing Protocol
- Static IPv4 routing, static IPv6 routing
- Remote Management Protocol
- SNMP 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, CLI
- Flow control, Layer 2 switching, auto-negotiation, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, port mirroring, Weighted Round Robin (WRR) queuing, IPv6 support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping, Cable Diagnostics Function, STP Root Guard, DHCP relay, Port Security, DHCP client, dual firmware images, Strict Priority Queuing (SPQ), port isolation, static routing, Class of Service (CoS), Single IP Management (SIM)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 26.6 cm x 16.2 cm x 4.4 cm
- 900 g
- Limited lifetime warranty
- Enclosure Type
- Desktop, rack-mountable, wall-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- Capacity
- 8192 entries
- 10KB
- Routing Protocol
- Encryption Algorithm
- SSL
- Authentication Method
- Secure Shell (SSH), RADIUS
- Processor
- 1 x MIPS: 500 MHz
- RAM
- 128 MB SDRAM
- Flash Memory
- 32 MB
- 8 x 1000Base-T RJ-45 , 2 x 1000Base-X SFP , 1 x console RJ-45 management
- Voltage Required
- 9 Watt
- Rack Mounting Kit
- Included
- MTBF
- 128.2 years
- CISPR 22 Class A, EN 61000-3-3, EN55024, EN55022 Class A, UL 60950, ICES-003 Class A, RoHS, IEC 60950-1, EN 60950-1, WEEE, FCC Part 15 A, CAN/CSA C22.2 No. 60950-1-03, VCCI Class A, EN 61000-3-2:2000
- 26.6 cm
- 16.2 cm
- 4.4 cm
- 900 g
- Limited warranty - advance parts replacement - lifetime - response time: next business day , Product info support - phone consulting - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 10 - 95% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.07 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £10.55 |
C2G 2m Cat6a Shielded Patch - Blue | In Stock | £6.44 |
C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue | In Stock | £40.80 |
