HPE HP 1920-24G-PoE+ Switch
Quicklinx: B92PWS00 Mfr#: JG925A
The HPE 1920 Switch Series, part of the HPE OfficeConnect portfolio, is designed for smaller organizations dealing with bandwidth-demanding applications. The switches are ideal for environments that require advanced features for granular control and where smart-managed flexibility is a must for easy network configuration and management. The switches deliver advanced smart-managed fixed configuration Gigabit switches that build on the marketing-leading price/performance of the HPE 1910 Switch Series. They feature a new 48-port PoE+ model, IPv6 support and advanced silicon technology.
  • Simplifies Network Deployment and Management for Small Organizations
    The HPE 1920 Switch Series, ideal for small organizations features easy-to-use, out of the box, plug-and-play deployment.The series offers a complete portfolio of choices for increased flexibility. It consists of nine rack-mountable models with internal power supplies including four non-Power over Ethernet (PoE) models: 8G-, 16G-, 24G- and 48G- port; five PoE+ models: (2) 8G-, (2) 24G- and 48G-port.These smart-managed switches use an intuitive Web management interface, based on our industry-leading HPE 1910 Switch Series, to simplify deployment and management while offering you greater granularity of control of key features.
  • Keeps Your Business up and Running and Protected
    The HPE 1920 Switch Series with upgraded models and options is built on the market-leading, proven reliability of the HPE 1910 Switch Series with advanced silicon technology for lower power consumption and an enhanced feature set for more robust operation.Enhanced security features such as Access Control List, IEEE 802.1x and VLANs guard your network from unwanted or unauthorized access.Management security restricts access to critical configuration commands, offers multiple privilege levels with password protection and supports secure http (https).The switch series is covered by the Limited Lifetime Warranty.
  • Delivers Improved Performance, While Lowering the Total Cost of Ownership
    The HPE 1920 Switch Series delivers advanced functionality in smart-managed switches, including Layer 3 static routes, SFP ports, IPv6 support, rate limiting, link aggregation and IGMP.Smaller enclosures facilitate flexible deployment.The switch series includes PoE+ options to power IP devices without the cost of additional cabling.Advanced silicon technology, green features like Port shutdown and EEE compliance for greater energy-efficiency and the Limited Lifetime Warranty significantly reduce TCO.
HPE 1920-24G-PoE+ - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L3 - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE+) + 4 x Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
180 W
Performance
Throughput: 41.7 Mpps , Routing/switching capacity: 56 Gbps
IPv4 routing table entries: 32 , IPv6 routing table entries: 32
MAC Address Table Size
8192 entries
Jumbo Frame Support
10KB
Routing Protocol
Static IPv4 routing, static IPv6 routing
Remote Management Protocol
SNMP 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, CLI
Flow control, Layer 2 switching, auto-negotiation, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, port mirroring, Weighted Round Robin (WRR) queuing, IPv6 support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping, Cable Diagnostics Function, STP Root Guard, DHCP relay, Port Security, DHCP client, dual firmware images, Strict Priority Queuing (SPQ), port isolation, static routing, Class of Service (CoS), Single IP Management (SIM)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
44 cm x 23.8 cm x 4.4 cm
3.4 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
180 W
Performance
8192 entries
Jumbo Frame Support
10KB
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS
1 x MIPS: 500 MHz
RAM
128 MB SDRAM
Flash Memory
32 MB
24 x 1000Base-T RJ-45 PoE+ , 4 x 1000Base-X SFP , 1 x console RJ-45 management
235 Watt
Rack Mounting Kit
Included
MTBF
68.96 years
CISPR 22 Class A, EN 61000-3-3, EN55024, EN55022 Class A, UL 60950, ICES-003 Class A, RoHS, IEC 60950-1, EN 60950-1, WEEE, FCC Part 15 A, CAN/CSA C22.2 No. 60950-1-03, VCCI Class A, EN 61000-3-2:2000
44 cm
23.8 cm
4.4 cm
3.4 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day , Product info support - phone consulting - 3 years
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
10 - 95% (non-condensing)
B92P C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
