Quickly and easily backup your files and transfer your data, pictures, video, and projects between your PC and 15 types of storage media with the HP 15-in-1 Media Card Reader.
- HP 15-in-1 USB2/3 Media Card Reader - card reader - USB 3.0
- Product Type
- Card reader - internal - 15 in 1
- Supported Memory Cards
- CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, Microdrive, SD Memory Card, Memory Stick Duo, Memory Stick PRO Duo, SDHC Memory Card, Memory Stick PRO-HG Duo, SDXC Memory Card, Memory Stick Select, SDHC UHS-II Memory Card
- Host Interface
- USB 3.0
- Required Bay
- 3.5" internal
- 1-year warranty
- Designed For
- EliteDesk 700 G1, 800 G1 (SFF, tower); ProDesk 400 G1 (micro tower, SFF), 405 G1 (micro tower), 490 G1 (micro tower), 600 G1 (SFF, tower)
- Product Type
- Supported with Optional Adapter
- miniSD, microSD, miniSDHC, Memory Stick Micro (M2), microSDHC
- Host Interface
- USB 3.0
- Required Bay
- 3.5" internal
- 124.5 mm
- 101.6 mm
- 25.4 mm
- 0.16 kg
Memory Card
- Capacity
- (max)
- Required Ports
- 1 x 20 pin USB 3.0 header
- OS Required
- Microsoft Windows XP Professional, Microsoft Windows 7 Home Basic, Microsoft Windows 7 Home Premium (32/64 bits), Microsoft Windows Vista Business (32/64 bits), Microsoft Windows 7 Professional (32/64 bits), Microsoft Windows 7 Ultimate (32/64 bits), Microsoft Windows Vista Home Basic 32-bit Edition, Windows 8 64-bit Edition, Windows 8 Pro 64-bit Edition, Microsoft Windows XP Home Edition (32 bit), Windows 8.1 64-bit Edition
- Included Accessories
- 5.25-inch bay adapter
- VCCI, C-Tick, BSMI, cUL, WHQL, MIC, FCC, USB-IF, TUV T
- Limited warranty - parts and labour - 1 year
- Designed For
- HP EliteDesk 700 G1, 800 G1 (SFF, tower) , HP ProDesk 400 G1 (micro tower, SFF), 405 G1 (micro tower), 490 G1 (micro tower), 600 G1 (SFF, tower)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.07 |
