Your basket is empty
HPE HP 146GB 6G SAS 15K 2.5 Inch HDD
Quicklinx: C4VFWS00 Mfr#: 653950-001
Form Factor: 2.5" SFF
Type: Hard drive
Capacity: 146GB
Spin Speed (rpm): 15000rpm
£137.26 ex VAT
£164.71 inc VAT
HP 146GB 2.5-inch (SFF) Serial Attached SCSI (SAS) 6G 15K Hot-Plug Hard Drive in G8 G9 (Gen8 Gen9) SmartDrive Carrier (SC).
SAS is the logical evolution of SCSI including its long-established software advantage and the serial physical connection interface. With enterprise storage requirements escalating and becoming more complex factors such as larger capacity greater density security scalability and accessibility are more critical than ever. Enterprise data centers must be online all the time fulfill requests from numerous users simultaneously allow for constant growth and expansion and be maintained while in operation. Serial Attached SCSI meets all these demands while providing the highest performance.
HP - hard drive - 146 GB - SAS 6Gb/s
Hard drive - hot-swap
146 GB
2.5" SFF
SAS 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
15000 rpm
6 months warranty
146 GB
2.5" SFF
SAS 6Gb/s
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
15000 rpm
Expansion & Connectivity
1 x SAS 6Gb/s
Compatible Bays
1 x hot-swap - 2.5" SFF
6 months warranty
Service & Support Details
Limited warranty - 6 months
HPE HP 146GB 6G SAS 15K 2.5 Inch HDD Bundle deal on HPE HP 146GB 6G SAS 15K 2.5 Inch HDD
£153.58
saving £7.71
Type: Hard drive
Capacity: 146GB
Brand: HPE
Price Range Ex VAT: 100 - 150
