Product
Brand
HPE HP 146 GB hot-swap 2.5" SFF - SAS - 10000rpm Hard Drive
Quicklinx: 9ZS7WS00 Mfr#: 432320-001
HPE - hard drive - 146 GB - SAS
Hard drive - hot-swap
146 GB
2.5" SFF
SAS
Data Transfer Rate
300 MBps
Spindle Speed
10000 rpm
ProLiant BL20p G4, BL25p G2, BL45p G2, BL460c, BL465c, BL465c G5, BL480c, BL680c G5, BL685c, BL685c G5, DL360 G4p, DL360 G5, DL365, DL365 G5, DL380 G4, DL380 G5, DL385, DL385 G2, DL385 G5, DL385 G5p, DL385 G6, DL580 G3, DL580 G4, DL580 G5, DL585, DL585 G2, DL585 G5, DL785 G5, ML350 G5, ML370 G4, ML370 G5, ML570 G3, ML570 G4
146 GB
2.5" SFF
SAS
Performance
Drive Transfer Rate
300 MBps (external)
Spindle Speed
10000 rpm
Expansion & Connectivity
1 x SAS
Compatible Bay
2.5" SFF
RoHS
HPE ProLiant BL20p G4 (2.5"), BL25p G2 (2.5"), BL45p G2 (2.5"), BL460c (2.5"), BL465c (2.5"), BL465c G5 (2.5"), BL480c (2.5"), BL680c G5 (2.5"), BL685c (2.5"), BL685c G5 (2.5"), DL360 G4p (2.5"), DL360 G5 (2.5"), DL360 G5 Base (2.5"), DL360 G5 Entry (2.5"), DL360 G5 High Efficiency (2.5"), DL360 G5 Performance (2.5"), DL365 (2.5"), DL365 Base (2.5"), DL365 Entry (2.5"), DL365 G5 (2.5"), DL365 G5 Base (2.5"), DL365 G5 Entry (2.5"), DL365 G5 High Efficiency (2.5"), DL365 G5 Performance (2.5"), DL365 Performance (2.5"), DL380 G4 (2.5"), DL380 G4 High Performance (2.5"), DL380 G5 (2.5"), DL380 G5 Base (2.5"), DL380 G5 Entry (2.5"), DL380 G5 High Efficiency (2.5"), DL380 G5 High Performance (2.5"), DL385 (2.5"), DL385 G2 (2.5"), DL385 G2 Base (2.5"), DL385 G2 Entry (2.5"), DL385 G2 High Performance (2.5"), DL385 G5 (2.5"), DL385 G5 Base (2.5"), DL385 G5 Entry (2.5"), DL385 G5 Performance (2.5"), DL385 G5p Base (2.5"), DL385 G5p High Performance (2.5"), DL385 G6 (2.5"), DL385 G6 Base (2.5"), DL385 G6 Entry (2.5"), DL385 G6 High Performance (2.5"), DL580 G3 (2.5"), DL580 G4 (2.5"), DL580 G4 High Performance (2.5"), DL580 G5 (2.5"), DL580 G5 Base (2.5"), DL580 G5 High Performance (2.5"), DL585 (2.5"), DL585 G2 (2.5"), DL585 G5 (2.5"), DL785 G5 (2.5"), ML350 G5 (2.5"), ML350 G5 Base (2.5"), ML370 G4 (2.5"), ML370 G4 High Performance (2.5"), ML370 G5 (2.5"), ML370 G5 Base (2.5"), ML370 G5 Entry (2.5"), ML370 G5 High Performance (2.5"), ML370 G5 Performance (2.5"), ML570 G3 (2.5"), ML570 G3 High Performance (2.5"), ML570 G4 (2.5"), ML570 G4 High Performance (2.5")
