Are you looking for a rack to fit your compute solution that's designed to perform and at a reasonable price? Perfect for the server room or today's modern data center, HP Advanced Series Racks provide the innovations you need while maintaining a focus on performance. With a 3000 pound capacity, the welded frame is designed for durability and includes a door with greater perforation for better airflow. Designed for scalability, performance and ease of maintenance a rear bracket eases installation and management of cable and power distribution. Advanced Series Racks are also compatible with HP Location Discovery Services to speed implementation of new equipment and speed asset tracking. Manual, error-prone asset management is removed because servers can now self-identify and inventory themselves. For those that require greater load capacity, choose HP Advanced Series Racks that can be fully configured and shipped to your site.
The Stronger the Rack, the Longer it Lasts
HPE Advanced Series Racks are covered by a standard 3-year warranty.Heavy-gauge mounting rails support up to 3000 pounds (static load) and 2250 pounds (dynamic load), keeping a fully loaded rack safe in the truck and in the datacenter.Fully-tested ship load allows racks to be shipped fully configured, reducing time to deployment.Universal rack design compatible with all Hewlett Packard Enterprise rack mount products including servers, networking, and storage.Full line of options and accessories to create the rack that supports your compute solution needs. -
Our Racks Give you More for Less, Keeping your Servers Working Hard and you Working Easy
HPE Advanced Series Racks provide the industry's widest range of rack enclosures that supports a broad variety of workloads and configurations.Improved cable management provisions simplify installation, organization and maintenance.Hewlett Packard Enterprise Foundation Care services purchased for servers and storage extend to our rack and power infrastructure products. What is the HPE advantage for you? Save $$$.An extensive range of rack, power, and KVM products to outfit your rack.
- HPE 600mm x 1075mm Advanced Pallet Rack - rack - 42U
- Product Type
- Rack
- Black
- Height (Rack Units)
- 42U
- 59.78 cm x 111.32 cm x 200.66 cm
- 107 kg
- Designed For
- ProLiant DL120 Gen9, DL180 Gen9, DL20 Gen9, DL380 Gen9, DL60 Gen9, DL80 Gen9, ML350 Gen9
- Product Type
- Rack
- 42U
- 59.78 cm
- 111.32 cm
- 200.66 cm
- 107 kg
- Black
- Limited warranty: - 3 years
- Designed For
- HPE ProLiant DL120 Gen9, DL120 Gen9 Entry, DL180 Gen9, DL180 Gen9 Base, DL180 Gen9 Entry, DL180 Gen9 Storage, DL20 Gen9, DL20 Gen9 Entry, DL20 Gen9 Performance, DL380 Gen9, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 High Performance, DL380 Gen9 Performance, DL60 Gen9, DL60 Gen9 Base, DL60 Gen9 Entry, DL80 Gen9, DL80 Gen9 Base, DL80 Gen9 Entry, ML350 Gen9, ML350 Gen9 Base, ML350 Gen9 Entry, ML350 Gen9 Performance
