Product
Brand
HPE HP 11642 1075mm Pallet Rack
Quicklinx: B787WS00 Mfr#: H6J65A
Are you looking for a rack to fit your compute solution that's designed to perform and at a reasonable price? Perfect for the server room or today's modern data center, HP Advanced Series Racks provide the innovations you need while maintaining a focus on performance. With a 3000 pound capacity, the welded frame is designed for durability and includes a door with greater perforation for better airflow. Designed for scalability, performance and ease of maintenance a rear bracket eases installation and management of cable and power distribution. Advanced Series Racks are also compatible with HP Location Discovery Services to speed implementation of new equipment and speed asset tracking. Manual, error-prone asset management is removed because servers can now self-identify and inventory themselves. For those that require greater load capacity, choose HP Advanced Series Racks that can be fully configured and shipped to your site.
HPE 600mm x 1075mm Advanced Pallet Rack - rack - 42U
Rack
Height (Rack Units)
42U
59.78 cm x 111.32 cm x 200.66 cm
107 kg
ProLiant DL120 Gen9, DL180 Gen9, DL20 Gen9, DL380 Gen9, DL60 Gen9, DL80 Gen9, ML350 Gen9
Rack
Height (Rack Units)
42U
59.78 cm
111.32 cm
200.66 cm
107 kg
Limited warranty - 3 years
HPE ProLiant DL120 Gen9, DL120 Gen9 Entry, DL180 Gen9, DL180 Gen9 Base, DL180 Gen9 Entry, DL180 Gen9 Storage, DL20 Gen9, DL20 Gen9 Entry, DL20 Gen9 Performance, DL380 Gen9, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 High Performance, DL380 Gen9 Performance, DL60 Gen9, DL60 Gen9 Base, DL60 Gen9 Entry, DL80 Gen9, DL80 Gen9 Base, DL80 Gen9 Entry, ML350 Gen9, ML350 Gen9 Base, ML350 Gen9 Entry, ML350 Gen9 Performance
