Product
Brand
HPE HP 10Gbe al Switch Interconnect Kit
Quicklinx: 7DJDWS00 Mfr#: J9165A
The HP 10-GbE Interconnect Kit's two 1 port CX4 modules are designed for short distance interconnection.
HPE 10-GbE Interconnect Kit - expansion module
Expansion module
Packaged Quantity
2 (specifications are for single item)
Plug-in module
Ports
10GBase-CX4
10.6 cm x 10.4 cm x 3.6 cm
140 g
Cabling Type
Ethernet 10GBase-CX4
10 GigE
Data Transfer Rate
10 Gbps
HPE 2910-24G al Switch, 2910-24G-PoE+ al Switch, 2910-48G al Switch, 2910-48G-PoE+ al Switch
Packaged Quantity
Expansion module
Plug-in module
Ports
10GBase-CX4
Wired
Cabling Type
10 GigE
Data Transfer Rate
10 Gbps
1 x 10GBase-CX4
Compatible Slots
1 x Expansion Slot
1 x network cable - 50 cm
10.6 cm
10.4 cm
3.6 cm
140 g
50 °C
15 - 95%
