Your basket is empty
HPE HP 1 Port PoE Injector
Quicklinx: 7T2KWS00 Mfr#: J9407B
The HP 1-port power injector provides 802.3af PoE power for an access point in areas where using an AC power supply of a traditional PoE switch is inconvenient.
HPE 1-port Power Injector - PoE injector
PoE injector
450 g
5.1 cm x 14 cm x 3.3 cm
1 year warranty
HPE 103, 205, 350, 355, 417, 425, 501, 517, 525, 527, 560, M200 802.11n, MSM310, MSM310-R, MSM313, MSM320, MSM320-R, MSM325, MSM335, MSM710
PoE injector
Input Voltage Range
AC 100 - 240 V
Frequency Required
50/60 Hz
1 x Gigabit LAN - RJ-45
FCC Class B certified, EN 60950, EN55024, UL 60950, CISPR 22, EN55022 Class B, FCC Part 15
Limited warranty - 1 year
5 - 93% (non-condensing)
5.1 cm
14 cm
3.3 cm
450 g
HPE 103 Instant (US), 103 Instant (WW), 205 Instant (US), 205 Instant (WW), 350 Cloud-Managed Access Point (JP), 350 Cloud-Managed Access Point (US), 350 Cloud-Managed Access Point (WW), 355 (WW), 355 Cloud-Managed Access Point (JP), 355 Cloud-Managed Access Point (US), 417 (AM), 417 (AM) Eco-pack, 417 (WW), 417 (WW) Eco-pack, 425 (AM), 425 (AM) 8 unit Eco-pack, 425 (AM) Eco-pack, 425 (IL), 425 (JP), 425 (WW), 425 (WW) 8 unit Eco-pack, 425 (WW) Eco-pack, 501 Wireless Client Bridge, 517 (AM), 517 (IL), 517 (JP) Unified Wired-WLAN Walljack, 517 (WW), 525 (AM), 525 (AM) Eco-pack, 525 (IL), 525 (JP), 525 (WW), 525 (WW) Eco-pack, 527 (AM) Eco-pack, 527 (AM) Unified Wired-WLAN Walljack, 527 (IL) Unified Wired-WLAN Walljack, 527 (JP) Unified Wired-WLAN Walljack, 527 (WW), 527 (WW) Eco-pack, 560 (AM), 560 (IL), 560 (JP), 560 (WW), M200 802.11n Access Point (US), M200 802.11n Access Point (WW), MSM310 Access Point JP, MSM310 Access Point US, MSM310 Access Point WW, MSM310-R Access Point US, MSM310-R Access Point WW, MSM313 Access Point JP, MSM313 Access Point US, MSM320 Access Point JP, MSM320 Access Point US, MSM320 Access Point WW, MSM320-R Access Point JP, MSM320-R Access Point US, MSM320-R Access Point WW, MSM325 Access Point US, MSM325 Access Point WW, MSM335 Access Point US, MSM335 Access Point WW, MSM710 Access Controller, MSM710 Mobility Controller
7T2K C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.08
7T2K C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.53
7T2K C2G 2m Cat6a Shielded Patch - Blue In Stock £6.47
7T2K C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £41.04
