Your basket is empty
HPE HP - Hard drive - 500 GB - SATA-600 - 7200 rpm - for Workstation z210
Quicklinx: 8326WS00 Mfr#: LQ036AA
Form Factor: 3.5" x 1/3H
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 500GB
Spin Speed (rpm): 7200rpm
Hurry, only 2 left in stock!
£74.73 ex VAT
£89.67 inc VAT
Express delivery Order within the next 20 hours for delivery on Wednesday
SATA 7200 rpm drives are our standard high bandwidth hard drive storage options; most workstation models are also available with high performance 10K rpm rotation speeds. Storage capabilities range up to a massive 2.0 TB.
HP - hard drive - 500 GB - SATA 6Gb/s
Hard drive - internal
500 GB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
16 MB
Spindle Speed
7200 rpm
8.89 cm x 10.17 cm x 2.54 cm
Workstation z210, Z220, Z230, Z420, Z620, Z820
500 GB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
16 MB
8.89 cm
10.17 cm
2.54 cm
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" x 1/3H
HP Workstation z210, Z220, Z230, Z420, Z620, Z820
HPE HP - Hard drive - 500 GB - SATA-600 - 7200 rpm - for Workstation z210 Bundle deal on HPE HP - Hard drive - 500 GB - SATA-600 - 7200 rpm - for Workstation z210
£91.05
saving £8.65
Cables
Including:
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £6.01 | in stock
£77.74
saving £3.01
Type: Hard drive
Capacity: 500GB
Brand: HPE
Stock Status: Clearance
Price Range Ex VAT: 50 - 100
