Your basket is empty
HPE HP - 20 x LTO Ultrium 3 - 400GB/800GB - labeled - storage media
Quicklinx: 52QRWS00 Mfr#: C7973AN
Type: LTO Ultrium
Native Capacity: 400GB
£360.77 ex VAT
£432.92 inc VAT
With HPE Non-custom Labeled LTO Ultrium media, you no longer have to label your own cartridges, saving you time and the risk of retrieval errors. Barcode sequences are unique to each batch ordered – no codes are repeated. HPE rigorously tests its precision-engineered, high-resolution barcode labels using software unique to the HPE Automation Group to evaluate and warrant the performance of its labels in demanding, split-second datacenter environments. These labels are professionally applied in a clean environment to ensuring 100% readability accurate storage. Non-Custom Labeled cartridges ensure 100% label readability and can be ordered online, in packs of 20, using a fast and simple process. For those customer who value the added security that RFID adds, customers have the option to integrate it into each label at minimal cost. The RFID tag is embedded into the back of the non-custom label and offers tracking, audit and security advantages for those with IT asset tracking systems.
HPE - LTO Ultrium x 20 - 400 GB - storage media
Storage media - LTO Ultrium
Tape Cartridge
Ultrium 3
Media Included Qty
20
Native Capacity
400 GB
Compressed Capacity
800 GB
Tape Length
680 m
Cartridge Labeling
Labeled
StorageWorks ESL9000, ESL9198, ESL9198SL, ESL9322, ESL9322L1, ESL9322L2, ESL9322S2, ESL9326, ESL9326D, ESL9326SL, ESL9595, ESL9595L1, ESL9595L2, ESL9595S2, ESL9595SL, MSL2024, MSL4048, MSL6030, MSL6060, SAS Rack-Mount Kit, SSL1016; StorageWorks 1/8 G2 Tape Autoloader; StorageWorks Ultrium 920
LTO Ultrium
Tape Cartridge
Ultrium 3
Media Included Qty
20
Cartridge Labeling
Labeled
Media
Native Capacity
400 GB
Compressed Capacity
800 GB
Tape Length
680 m
Archival Life
30 years
10 °C
45 °C
10 - 80%
HPE StorageWorks ESL9000, ESL9198, ESL9198SL, ESL9322, ESL9322L1, ESL9322L2, ESL9322S2, ESL9326, ESL9326D Enterprise Library, ESL9326SL, ESL9595, ESL9595L1, ESL9595L2, ESL9595S2, ESL9595SL, MSL2024 Ultrium 960, MSL4048, MSL4048 Ultrium 960, MSL6030 Ultrium 960, MSL6060 Ultrium 960, SAS Rack-Mount Kit, SSL1016, SSL1016 Tape Autoloader , HPE StorageWorks 1/8 G2 Tape Autoloader Ultrium 920 , HPE StorageWorks Ultrium 920
Type: LTO Ultrium
Brand: HPE
Price Range Ex VAT: 300 - 500
