Exhaustively tested, HP LTO Ultrium cartridges meet all your demands for maximum reliability when restoring data, offering high storage density, ease of management and scalable storage and backup performance. Covering six generations of capacity - LTO-1 (200 GB), LTO-2 (400 GB), LTO-3 (800 GB), LTO-4 (1.6 TB), LTO-5 (3 TB), LTO-6 (6.25 TB) – and with transfer speeds of up to 1.4 TB/hr for LTO-6, there is a platform for every need and budget. From LTO-3 onwards, LTO Ultrium WORM cartridges enable the creation of compliant, permanent and tamperproof archives. From LTO-4 onwards, secure AES-256 encryption provides even higher levels of data security and compliance with the most stringent industry regulations to prevent unauthorized data access. From LTO-5 onwards, LTO Ultrium Linear Tape File System makes using tape as easy, flexible, portable and intuitive as using other removable and sharable media, such as a USB drive.
Highest Capacity and Performance of any Comparable Tape Technology
HPE LTO-8 Ultrium can write or read data at a blistering 2.7 TB/hour, storing, encrypting and protecting up to 30 TB on a single cartridge, making it ideal for large-scale, 24 x 7, mission-critical IT environments (assumes 2.5:1 compression).An 85% increase in the number of tracks and a 8% increase in bit density has permitted an increase in capacity from 15 TB for LTO-7 to 30 TB to LTO-8: from 3,584 tracks for LTO-6 to 6,656 tracks for 8th generation HPE LTO-8 Ultrium 30 TB cartridges (assuming 2.5:1 compression).HPE LTO Ultrium cartridge memory chip delivers faster access time and enhanced media monitoring.First time restore ensured with fewer media failures and disrupted backups, regardless of duty cycle or environmental conditions. -
Ultra-reliable
Tape is more reliable than Enterprise SATA disk. With a BER of 1x10 to the power of 19 for LTO-8 versus 1x10 to the power of 15 for Enterprise SATA HDD's. That's a difference in reliability of four orders of magnitude – e.g. tape is 10,000 times more reliable than Enterprise SATA HDD.Estimated data loss over 10-years for 1 PB archive is 1.1 TB for Enterprise HDD versus 7.4 TB for LTO-8 tape.Superior 'smart grabber' mechanism and mechanical interlock to prevent the leader pin from being pulled inside the tape housing. Sensors detect proper connection and prevent leader loss that would ruin the tape. Simplified tape path to reduce wear, tear & build-up of debris (important in automation).HPE brand qualification test procedures (load/unload, shoeshine, drop testing and environmental stress testing) go far beyond what is required for the LTO Ultrium logo.This ensures maximum reliability for restoring your data.HPE warrants LTO Ultrium cartridges for up to 30 years archival life. This ensures businesses can meet the ever-increasing demands of regulation for data retention and archiving. -
Secure
Write-Once-Read-Many (WORM) version provides tamper-proof, compliant data storage.Data encryption for enhanced data security on HP LTO-4, LTO-5, LTO-6, LTO-7 and LTO-8 Ultrium. Compliance with FIPS 140-2 level 1 security standards. -
Value for money
Standardizing on HPE LTO Ultrium delivers the capacity to meet shrinking backup windows, industry-standard, AES 256-bit encryption (IEEE1619.1), and interchangeable RW or WORM media; without extra space or IT resource overhead.Open standard technology ensures compatibility across product generations and gives you more choice. Cartridges are available as Custom Labeled, Non-Custom Labeled (both Custom and Non Custom include RFID options for some formats) and non-labeled versions.
- HPE - LTO Ultrium 2 x 20 - 200 GB - storage media
- Storage media - LTO Ultrium
- Tape Cartridge
- Ultrium 2
- Media Included Qty
- 20
- Native Capacity
- 200 GB
- Compressed Capacity
- 400 GB
- Tape Length
- 609 m
- Limited lifetime warranty
- Designed For
- 1/8 G2 Tape Autoloader; LTO-5 Ultrium; StorageWorks MSL2024, MSL4048, MSL6030, SAS Rack-Mount Kit, Ultrium 448, Ultrium 460; StorageWorks 1/8 G2 Tape Autoloader; 1/8 Tape Autoloader; StorageWorks Enterprise Modular Library E-Series; StorageWorks Ultrium 448, 460, 920; Ultrium 448
- LTO Ultrium
- Tape Cartridge
- Ultrium 2
- 20
Media
- Native Capacity
- 200 GB
- 400 GB
- Tape Length
- 609 m
- Archival Life
- 30 years
- 10 °C
- 45 °C
- 10 - 80%
- Designed For
- HPE 1/8 G2 Tape Autoloader Ultrium 1760 , HPE LTO-5 Ultrium 3000 , HPE StorageWorks ESL9322, ESL9595, MSL2024 Ultrium 448, MSL2024 Ultrium 960, MSL4048 Ultrium 960, MSL6030, MSL6030 Ultrium 960, MSL6060, SAS Rack-Mount Kit, Ultrium 448 Drive Upgrade Kit, Ultrium 460 Drive Upgrade Kit , HPE StorageWorks 1/8 G2 Tape Autoloader Ultrium 448, Ultrium 920 , HPE StorageWorks 1/8 Tape Autoloader Ultrium 448, Ultrium 460 , HPE StorageWorks Enterprise Modular Library E-Series , HPE StorageWorks Rack-Mount Kit Ultrium 448 Drive, Ultrium 460 Drive , HPE StorageWorks SSL1016 Tape Autoloader Ultrium 460 , HPE StorageWorks Ultrium 448, 448 Array Module, 448 Drive Upgrade Kit, 460, 460 Drive upgrade kit, 460-FC, 460-FC Drive Upgrade Kit, 460m, 920, 960 , HPE SureStore Ultrium 448, 460 , HPE Trade-Ready Tape Drive Ultrium 448 , HPE Ultrium 448
