SATA 7200 rpm drives are our standard high bandwidth hard drive storage options; most workstation models are also available with high performance 10K rpm rotation speeds. Storage capabilities range up to a massive 2.0 TB.
- HP - hard drive - 500 GB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 500 GB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 16 MB
- Spindle Speed
- 7200 rpm
- 8.89 cm x 10.17 cm x 2.54 cm
- Designed For
- Workstation Z1 G5 Entry, Z2 G4, Z2 G5, Z2 G8, Z2 G9 (SFF, tower), z210, Z220, Z230, Z238, Z4 G4, Z420, Z6 G4, Z620, Z640 (3.5"), Z8 G4, Z820
- Capacity
- 500 GB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Buffer Size
- 16 MB
- 8.89 cm
- 10.17 cm
- 2.54 cm
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Spindle Speed
- 7200 rpm
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5" x 1/3H
- Shipping Width
- 23.2 cm
- Shipping Depth
- 18.4 cm
- Shipping Height
- 9.5 cm
- Designed For
- HP Workstation Z1 G5 Entry, Z2 G4, Z2 G5, Z2 G8, Z2 G9 (SFF, tower), z210, Z220, Z230, Z238, Z4 G4, Z420, Z6 G4, Z620, Z640 (3.5"), Z8 G4, Z820
