The HP H221 Host Bus Adapter (HBA) is compatible with select HP ProLiant Gen8 rack servers and tower servers, and provides customers with the flexibility and speed they have come to expect from HP. It features eight external SAS ports (two 4x external connectors) that now support HP SAS tape drives as well as 6Gb/s SAS and SATA hard drives with second generation performance. The H221 HBA has been optimized for connection to the HP P2000 G3 SAS Modular Smart Array, D2000 and D6000 Disk Enclosures, and MSA2040 SAS storage and is designed to drive cost-effective and reliable scalability in today's data centers.
Greater Performance and Flexibility
6 Gb/s SAS ASIC provides great performance for shared storage.Unlike previous generations, the HPE H221 HBA supports SAS Tape Drives offered by Hewlett Packard Enterprise.Two external x4 SAS ports offer flexibility in connecting shared devices to optimize system performance.
- HPE H221 Host Bus Adapter - storage controller - SATA 6Gb/s / SAS 6Gb/s - PCIe 3.0 x8
- Storage controller - plug-in module - low profile
- Bus Type
- PCIe 3.0 x8
- Interface
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Hard drive
- Channel Qty
- 8
- System Requirements
- SuSE Linux Enterprise Server 11, Microsoft Windows Server 2008 SP2, SuSE Linux Enterprise Server 10, Red Hat Enterprise Linux 5, Red Hat Enterprise Linux 6, Microsoft Windows Server 2008 R2 SP1, VMware ESX 4.1, VMware ESXi 4.1, Microsoft Windows Server 2012, VMware ESXi 5.1, VMware ESXi 5.0
- 1.6 cm x 16.8 cm x 6.86 cm
- 1-year warranty
- Designed For
- Modular Smart Array 2040, 2040 10Gb, P2000 G3; ProLiant DL160 Gen8, DL320e Gen8, DL360p Gen8, DL380p Gen8, DL385p Gen8, DL560 Gen8, ML10 v2, ML310e Gen8, ML350e Gen8, ML350p Gen8, SL4540 Gen8
- Host Bus
- PCIe 3.0 x8
Storage Controller
- Interface
- 6 Gbit/s
- Supported Devices
- Hard drive
- Channel Qty
- 8
- 2 x SATA 6Gb/s / SAS 6Gb/s - 26 pin 4x Shielded Mini MultiLane SAS (SFF-8088) (external)
- WEEE
- OS Required
- Limited warranty - parts - 1 year
- 1.6 cm
- 16.8 cm
- 6.86 cm
- Designed For
- HPE Modular Smart Array 2040 10Gb iSCSI Dual Controller SFF Bundle, 2040 Dual Controller SFF Bundle, 2040 FC Dual Controller SFF Bundle, 2040 SAN Dual Controller SFF Bundle, 2040 SAS Dual Controller LFF Storage, 2040 SAS Dual Controller SFF Bundle, P2000 G3 10GbE iSCSI Dual Controller SFF Array System , HPE ProLiant DL160 Gen8, DL160 Gen8 Base, DL160 Gen8 Entry, DL160 Gen8 Performance, DL320e Gen8, DL320e Gen8 Base, DL320e Gen8 Entry, DL320e Gen8 Performance, DL320e Gen8 v2, DL320e Gen8 v2 Base, DL320e Gen8 v2 Performance, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL360p Gen8 Performance, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Performance, DL380p Gen8 Special, DL385p Gen8, DL385p Gen8 Dedicated Workload, DL385p Gen8 Entry, DL385p Gen8 Maximized Consolidation, DL385p Gen8 Storage, DL385p Gen8 Storage Centric, DL560 Gen8, DL560 Gen8 Base, DL560 Gen8 Entry, DL560 Gen8 Performance, ML10 v2, ML10 v2 Base, ML10 v2 Entry, ML10 v2 Performance, ML310e Gen8, ML310e Gen8 Base, ML310e Gen8 Entry, ML310e Gen8 Performance, ML310e Gen8 v2, ML310e Gen8 v2 Base, ML310e Gen8 v2 Enty, ML310e Gen8 v2 Performance, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 Performance, ML350e Gen8 v2, ML350e Gen8 v2 Base, ML350p Gen8, ML350p Gen8 Base, ML350p Gen8 Entry, ML350p Gen8 Performance, ML350p Gen8 Special Server, SL4540 Gen8, SL4540 Gen8 Tray 2x Node Server
