Device Type: Hard drive Capacity: 450 GB Interface: SAS Internal Data Rate: 600 MBps
450GB hot-plug dual-port SAS hard disk drive - 10,000 RPM, 6Gb/sec transfer rate, 2.5-inch small form factor (SFF)
- HPE Dual Port - hard drive - 450 GB - SAS
- Hard drive
- Capacity
- 450 GB
- Interface
- SAS
- Spindle Speed
- 10000 rpm
- Designed For
- Integrity BL860c i4; ProLiant BL460c G6, BL460c G7, BL465c G6, BL465c G7, BL620C G7, BL680c G7, BL685c G6, BL685c G7, DL120 G7, DL160 G6, DL160se G6, DL165 G7, DL180 G6, DL320 G6, DL360 G6, DL360 G7, DL370 G6, DL380 G6, DL380 G7, DL385 G6, DL385 G7, DL580 G7, DL585 G6, DL585 G7, DL785 G6, DL980 G7, ML350 G6, ML370 G6, WS460c G6
- Hard drive
- Capacity
- 450 GB
- Interface
- SAS
Performance
- Internal Data Rate
- 600 MBps
- Spindle Speed
- 10000 rpm
Expansion & Connectivity
- 1 x SAS
- Designed For
- HPE Integrity BL860c i4 (2.5") , HPE ProLiant BL460c G6 (2.5"), BL460c G7 (2.5"), BL465c G6 (2.5"), BL465c G7 (2.5"), BL620C G7 (2.5"), BL680c G7 (2.5"), BL685c G6 (2.5"), BL685c G7 (2.5"), DL120 G7 (2.5"), DL160 G6 (2.5"), DL160 G6 Special Server (2.5"), DL160se G6 (2.5"), DL165 G7 (2.5"), DL165 G7 Performance (2.5"), DL165 G7 Special Server (2.5"), DL180 G6 (2.5"), DL180 G6 Special Server (2.5"), DL320 G6 (2.5"), DL360 G6 (2.5"), DL360 G6 Base (2.5"), DL360 G6 Efficiency (2.5"), DL360 G6 Entry (2.5"), DL360 G6 Performance (2.5"), DL360 G7 (2.5"), DL360 G7 Base (2.5"), DL360 G7 Central Management Server (2.5"), DL360 G7 Efficiency (2.5"), DL360 G7 Entry (2.5"), DL360 G7 Performance (2.5"), DL360 G7 Special Server (2.5"), DL370 G6 (2.5"), DL370 G6 Base (2.5"), DL370 G6 High Performance (2.5"), DL370 G6 Performance (2.5"), DL370 G6 Special Server (2.5"), DL380 G6 (2.5"), DL380 G6 Base (2.5"), DL380 G6 Entry (2.5"), DL380 G6 High Efficiency (2.5"), DL380 G6 Performance (2.5"), DL380 G7 (2.5"), DL380 G7 Base (2.5"), DL380 G7 Efficiency (2.5"), DL380 G7 Entry (2.5"), DL380 G7 Performance (2.5"), DL380 G7 Special Server (2.5"), DL385 G6 (2.5"), DL385 G6 Base (2.5"), DL385 G6 Entry (2.5"), DL385 G6 High Performance (2.5"), DL385 G6 ICE Performance (2.5"), DL385 G7 (2.5"), DL385 G7 Base (2.5"), DL385 G7 Entry (2.5"), DL385 G7 HE (2.5"), DL385 G7 Performance (2.5"), DL580 G7 (2.5"), DL580 G7 Base (2.5"), DL580 G7 High Performance (2.5"), DL585 G6 (2.5"), DL585 G6 Base (2.5"), DL585 G6 Performance (2.5"), DL585 G7 (2.5"), DL585 G7 Base (2.5"), DL585 G7 Performance (2.5"), DL785 G6 (2.5"), DL785 G6 Base (2.5"), DL785 G6 Performance (2.5"), DL980 G7 (2.5"), ML350 G6 (2.5"), ML350 G6 Base (2.5"), ML350 G6 Performance (2.5"), ML350 G6 Special Server (2.5"), ML370 G6 (2.5"), ML370 G6 Base (2.5"), ML370 G6 Entry (2.5"), WS460c G6 Workstation (2.5")
