HPE DL380p Gen8 E5-2620 Base EU Server
Quicklinx: 81B7WS00 Mfr#: 642120-421
  • Xeon
  • Red Hat Enterprise Linux
What is your server bottleneck....storage, processing, expansion? No matter the bottleneck, the HP ProLiant DL380p Gen8 Server series can help. It sets the data center standard for 2U 2-socket rack servers with the latest in serviceability, enhanced configuration flexibility, customer-inspired design, and unmatched performance. The DL380p Gen8 Server offers the perfect solution for the dynamic compute requirements of growing small businesses as well as demanding data centers.
  • Improved Capacity and Performance on Compute and Storage
    Intel Xeon processor E5-2600 v2 product family offers increased performance, improved security and efficiency; ideal for demanding workloads.HPE SmartMemory, with speeds up to 1866MHz, prevents data loss and downtime with enhanced error handling while improving workload performance and power efficiency.GPU compute support to maximize performance.HPE SmartCache, a controller-based caching solution, caches hot data onto lower latency SSDs providing up to 4x better workload performance.* *Feb. 2013, Performance and config as outlined in Whitepaper TC1211951.
  • Unlock your Infrastructure's Potential with HP's Easy-to-Use Integrated Management and Support
    HPE iLO Management Engine is a complete set of embedded features, standard on all ProLiant Gen8 servers. Includes HPE iLO, HPE Agentless Management, HPE Active Health System, HPE Intelligent Provisioning, and HPE Embedded Remote Support.HPE Insight Online with HPE remote support provides 24X7 remote monitoring and anywhere, anytime personalized access to your IT and support status.HPE Smart Update, including HPE SUM, SPP and other products, reduces deployment time and update complexity by systematically and securely updating server infrastructure in the data center; in most cases the downtime is limited to a single reboot.
  • Energy Efficiency by Design
    HPE Common Slot Power Supplies provide a new level of efficiency with 80 PLUS Titanium certification (96%) and new infrastructure power efficiencies with 277VAC and 380VDC input voltages.First in industry to include 3D array of temperature sensors to help precisely control server fans to direct cooling and reduce unnecessary fan power, saving on cooling costs.ENERGY STAR qualified server configurations illustrate HP's continued commitment to helping customers conserve energy and save money.
  • Redefining the Customer Experience with HPE ProActive Insight Architecture
    User-inspired design features that prevent data loss, reduce downtime, and improve serviceability include HPE SmartDrives, HPE Smart Socket guides, "Easy Install" Rail kit options, and tool-less access to components.Integrated Lifecycle Automation provides a breakthrough in Converged Infrastructure management with simplified provisioning, proactive health monitoring and alerting, and automated firmware and system software maintenance.Dynamic Workload Acceleration converges storage, compute, and I/O to turbo-charge performance and resiliency while eliminating bottlenecks.Automated Energy Optimization reclaims space, power, and cooling resources needed for workloads and eliminates costly errors caused by manual operation activities in the data center.HPE Proactive Insight Experience enables industry leading performance, uptime and productivity utilizing a proactive, personalized, simplified support experience.
HPE ProLiant DL380p Gen8 Base - rack-mountable - Xeon E5-2620 2 GHz - 16 GB - no HDD
Server - rack-mountable - administrator password, power-on password, keyboard password, serial port I/O control, quick lock
Height (Rack Units)
2U
Region: Europe
Server Scalability
2-way
1 x Intel Xeon E5-2620 / 2 GHz (2.5 GHz) (6-core)
Cache Memory
15 MB L3 Cache
Cache Per Processor
15 MB
RAM
16 GB (installed) / 384 GB (max) - DDR3 SDRAM - PC3-10600
Storage Controller
RAID (SATA 3Gb/s / SAS 6Gb/s) - PCIe 3.0 x8 (Smart Array P420i)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
Matrox G200
GigE
Power Redundancy
Optional
44.6 cm x 69.9 cm x 8.7 cm
18.6 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
Server
Recommended Use
Small business, corporate business
Product Form Factor
Rack-mountable - 2U
Server Scalability
2-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
8
Region: Europe
Processor / Chipset
CPU
Intel Xeon E5-2620
Clock Speed
2 GHz
Max Turbo Speed
2.5 GHz
Number of Cores
6-core
64-bit Computing
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Chipset Type
Intel C600
Cache Memory
Installed Size
L3 Cache - 15 MB
Cache Per Processor
15 MB
RAM
Installed Size
16 GB / 384 GB (max)
DDR3 SDRAM
Effective Memory Speed
1333 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
DIMM 240-pin
Slots
24 (Total) / 20 (empty)
Registered, quad channel memory architecture, HP SmartMemory
Configuration Features
4 x 4 GB
RAM Supported
PC3-12800 - 384 GB registered , PC3-10600 - 768 GB , PC3-10600 - 128 GB unbuffered - Advanced ECC
Hard Drive
No HDD
Storage Controller
1 x RAID - plug-in card - PCIe 3.0 x8
Controller Interface Type
Storage Controller Name
Smart Array P420i
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10, RAID 50
Buffer Size
1 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Matrox G200
Video Interfaces
VGA
Input Device
Mouse, keyboard
Integrated
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
HP 331FLR
Remote Management Controller
Integrated Lights-Out 4
Wake on LAN (WoL), PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3ad (LACP)
Bays
1 (total) / 1 (free) x external 5.25" Slim Line , 8 (total) / 8 (free) x hot-swap 2.5" SFF
Slots
24 (total) / 20 (free) x DIMM 240-pin , 2 (total) / 1 (free) x CPU , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x8 - half-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x8 - half-length, full-height (x4 mode) , 1 (total) / 1 (free) x SD card (internal)
1 x serial , 2 x VGA (1 front, 1 rear) , 4 x LAN (Gigabit Ethernet) , 1 x HPE iLO , 6 x USB 2.0 (2 front, 4 rear)
HP Ball Bearing Rail Kit, cable management arm
Administrator password, power-on password, keyboard password, serial port I/O control, quick lock
ACPI 2.0b, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, BSMI CNS 13438
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Power Provided
460 Watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
94%
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Solaris
ENERGY STAR Certified
44.6 cm
69.9 cm
8.7 cm
18.6 kg
10 °C
35 °C
10 - 90% (non-condensing)
81B7 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.07
