HPE DL380 Gen9 Intel Xeon E5-2650v4 Kit
Quicklinx: CKGRWS00 Mfr#: 817943-B21
Socket: LGA2011-v3 Socket
Type: Xeon
Clock Speed: 2.2GHz
  • Xeon
Hurry, only 3 left in stock!
£879.74 ex VAT
£1,055.68 inc VAT
Intel® Turbo Boost Technology dynamically increases the processor's frequency as needed by taking advantage of thermal and power headroom to give you a burst of speed when you need it, and increased energy efficiency when you don’t.
Intel® vPro™ Technology is a set of security and manageability capabilities built into the processor aimed at addressing four critical areas of IT security:
1) Threat management, including protection from rootkits, viruses, and malware
2) Identity and web site access point protection
3) Confidential personal and business data protection
4) Remote and local monitoring, remediation, and repair of PCs and workstations.
Intel® Hyper-Threading Technology (Intel® HT Technology) delivers two processing threads per physical core. Highly threaded applications can get more work done in parallel, completing tasks sooner.
Intel Xeon E5-2650V4 / 2.2 GHz processor
Processor Type
Number of Cores
12-core / 24 threads
Cache
30 MB
Compatible Processor Socket
LGA2011-v3 Socket
Processor Qty
1
Clock Speed
2.2 GHz
Max Turbo Speed
2.9 GHz
Manufacturing Process
14 nm
ProLiant DL380 Gen9, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 High Performance, DL380 Gen9 Performance, DL380 Gen9 Scale-up SAP HANA Tailored Datacenter Integration Compute Block, DL380 Gen9 Special, for Microsoft Azure Stack; SimpliVity 380 Gen9 Node
Type / Form Factor
Number of Cores
12-core
Number of Threads
24 threads
Cache
30 MB
Cache Memory Details
Smart Cache - 30 MB
Processor Qty
1
Clock Speed
2.2 GHz
Max Turbo Speed
2.9 GHz
LGA2011-v3 Socket
14 nm
Thermal Design Power
105 W
PCI Express Revision
3.0
PCI Express Configurations
X16, x4, x8
PCI Express Lanes Qty
40
HPE ProLiant DL380 Gen9, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 High Performance, DL380 Gen9 Performance, DL380 Gen9 Scale-up SAP HANA Tailored Datacenter Integration Compute Block, DL380 Gen9 Special, for Microsoft Azure Stack , HPE SimpliVity 380 Gen9 Node
Type: Xeon
Clock Speed: 2.2GHz
Brand: HPE
Price Range Ex VAT: 750 - 1000
