Is your data center space constrained yet performance driven? The HP ProLiant DL360p Gen8 Server provides enterprise class 2-socket performance and efficiency in a space saving 1U size. With Gen8 enhanced serviceability and configuration flexibility, it is ideal for general purpose applications such as file/print, web, dynamic computing workloads, virtualization and cloud solutions.
Improved Capacity and Performance on Compute and Storage
Intel Xeon processor E5-2600 v2 product family offers maximum performance, memory, I/O connectivity and bandwidth for demanding workloads.The HP Smart Storage Administrator management and configuration application provides a single pane of glass for HP Smart Storage products and solutions.HP Smart Array Controllers maximize data availability, performance and capacity.HP SmartMemory, with speeds up to 1866 MHz, prevents data loss and downtime with enhanced error handling while improving workload performance and power efficiency. -
Unlock your Infrastructure's Potential with HP's Easy-to-Use Integrated Management and Support
HP iLO Management Engine is a complete set of embedded features, standard on all ProLiant Gen8 servers. Includes HP iLO, HP Agentless Management, HP Active Health System, HP Intelligent Provisioning, and HP Embedded Remote Support.HP Insight Control provides advanced management capabilities across the lifecycle of your HP ProLiant server infrastructure. HP iLO Advanced, a key component, provides enhanced remote server functions that reduce IT travel costs and decrease Time-To-Resolution.HP Insight Online with HP remote support provides 24X7 remote monitoring and anywhere, anytime personalized access to your IT and support status.HP SmartUpdate reduces deployment time and update complexity by systematically updating server infrastructure in the data center. Includes HP Smart Update Manager (HP SUM), Service Pack for ProLiant (SPP), and other products. -
Energy Efficiency by Design
HP Common Slot Power Supplies provide a new level of server power efficiency with 80 PLUS Titanium certification (96%), and new infrastructure power efficiencies with 277VAC and 380VDC input voltages.First in industry to include 3D array of temperature sensors to help precisely control server fans to direct cooling and reduce unnecessary fan power, saving on cooling costs.ENERGY STAR qualified server configurations illustrate HP's continued commitment to helping customers conserve energy and save money. -
Redefining the Customer Experience with HP ProActive Insight architecture
User-inspired design features that prevent data loss, reduce downtime, and improve serviceability include HP SmartDrives, HP Smart Socket guides, "Easy Install" rail kit options, and tool-less access to components.Integrated Lifecycle Automation provides a breakthrough in Converged Infrastructure management with simplified provisioning, proactive health monitoring and alerting, and automated firmware and system software maintenance.Automated Energy Optimization reclaims space, power, and cooling resources needed for workloads and eliminates costly errors caused by manual operation activities in the data center.HP Proactive Insight Experience enables industry leading performance, uptime and productivity utilizing a proactive, personalized, simplified support experience.
- HPE ProLiant DL360p Gen8 High Performance - rack-mountable - Xeon E5-2690 2.9 GHz - 32 GB - no HDD
- Server - rack-mountable - administrator password, power-on password, keyboard password, serial port I/O control, quick lock
- Height (Rack Units)
- 1U
- Localisation
- Region: Europe
- Server Scalability
- 2-way
- Processor
- 2 x Intel Xeon E5-2690 / 2.9 GHz (3.8 GHz) (8-core)
- Cache Memory
- 40 MB L3 Cache
- Cache Per Processor
- 20 MB
- RAM
- 32 GB (installed) / 384 GB (max) - DDR3 SDRAM - PC3-12800
- Storage Controller
- RAID (SATA 6Gb/s / SAS 6Gb/s) - PCIe 3.0 x8 (Smart Array P420i)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Matrox G200
- Networking
- GigE, 10 GigE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- 43.5 cm x 69.9 cm x 4.3 cm
- 14.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - on-site - response time: next business day
- Server
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Rack-mountable - 1U
- 2-way
- Front Accessible Bays Qty
- 1
- Hot-Swap Bays Qty
- 8
- Localisation
- Region: Europe
Processor / Chipset
- CPU
- Intel Xeon E5-2690
- Clock Speed
- 2.9 GHz
- Max Turbo Speed
- 3.8 GHz
- Number of Cores
- 8-core
- 64-bit Computing
- CPU Qty
- 2
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel C600
Cache Memory
- Installed Size
- L3 Cache - 40 MB
- 20 MB
RAM
- Installed Size
- 32 GB / 384 GB (max)
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- DIMM 240-pin
- Slots
- 24 (Total) / 20 (empty)
- Registered, quad channel memory architecture, HP SmartMemory
- Configuration Features
- 4 x 8 GB
- RAM Supported
- PC3-12800 - 384 GB registered , PC3-10600 - 768 GB , PC3-10600 - 128 GB unbuffered - Advanced ECC
Hard Drive
- No HDD
Storage Controller
- 1 x RAID - plug-in card - PCIe 3.0 x8
- Controller Interface Type
- SATA 6Gb/s / SAS 6Gb/s
- Storage Controller Name
- Smart Array P420i
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10, RAID 50
- Buffer Size
- 2 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Matrox G200
- Video Interfaces
- VGA
Input Device
- Mouse, keyboard
- Integrated
- Ethernet Ports
- 2 x 10 Gigabit Ethernet
- Ethernet Controller
- HP 530FLR
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet
- Remote Management Protocol
- IPMI 2.0, SMASH CLP
- Remote Management Controller
- Integrated Lights-Out 4
- Wake on LAN (WoL), PXE support
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3ad (LACP)
- Bays
- 1 (total) / 1 (free) x external 5.25" x 1/2H , 8 (total) / 8 (free) x hot-swap 2.5" SFF
- Slots
- 24 (total) / 20 (free) x DIMM 240-pin , 2 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x8 - low-profile , 1 (total) / 1 (free) x SD card (internal)
- 1 x serial , 1 x VGA , 2 x LAN (10Gigabit Ethernet) , 1 x HPE iLO , 6 x USB 2.0 (2 front, 4 rear)
- Administrator password, power-on password, keyboard password, serial port I/O control, quick lock
- ACPI 2.0b, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, BSMI CNS 13438
- Power supply - hot-plug
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Installed Qty
- 2
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 750 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
- Efficiency
- 92%
Operating System / Software
- OS Certified
- SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Solaris
- ENERGY STAR Certified
- 43.5 cm
- 69.9 cm
- 4.3 cm
- 14.5 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
