Product
Brand
HPE DL360p Gen8 E5-2609 Kit
Quicklinx: 957FWS00 Mfr#: 654766-B21
  • Xeon
Intel Xeon E5-2609 - 2.4 GHz - 4 cores - 4 threads - 10 MB cache - for ProLiant DL360p Gen8
1.81 kg
Minimum dimensions (W x D x H)
19.38 x 28.19 x 28.58 cm
The Intel Xeon processor E5-2600 product family is at the heart of a flexible and efficient data center that meets your diverse needs. These engineering marvels are designed to deliver the best combination of performance, energy efficiency, built-in capabilities, and cost-effectiveness. From virtualization and cloud computing to design automation or real-time financial transactions, you'll be delighted by better than ever performance and energy efficiency. I/O latency is dramatically reduced with Intel Integrated I/O, which helps you to eliminate data bottlenecks, streamline your operations, and increase your agility. The Intel Xeon processor E5-2600 product family - versatile processors at the heart of today's data center.
Intel Xeon E5-2609 / 2.4 GHz processor
Processor Type
Intel Xeon E5-2609
Number of Cores
Quad-Core / 4 threads
Cache
10 MB
64-bit Computing
Clock Speed
2.4 GHz
Manufacturing Process
32 nm
Intel Virtualization Technology
Type / Form Factor
Intel Xeon E5-2609
Number of Cores
Quad-Core
Number of Threads
4 threads
Cache
10 MB
64-bit Computing
Clock Speed
2.4 GHz
32 nm
Thermal Design Power
80 W
Architecture Features
Cache Memory
Installed Size
10 MB
