HPE DL360 GEN10 5118 2P 32G 8FF
Quicklinx: DDQYWS00 Mfr#: 867963-B21
Processor Type: Xeon Gold
Installed Memory: 32GB
Hard Drive Capacity: 0GB
Storage Type: No HDD
Processor Model: 5118
£4,823.80 ex VAT
£5,788.56 inc VAT
Does your data center need a secure, performance driven dense server that you can confidently deploy for virtualization, database, or high-performance computing? The HPE ProLiant DL360 Gen10 Server delivers security, agility and flexibility without compromise. It supports the Intel Xeon Scalable processor with up to a 71% performance gain and 27% increase in cores , along with 2666 MT/s HPE DDR4 SmartMemory supporting up to 3.0 TB with an increase in performance of up to 66% . With the added performance that 12 NVDIMMs and 10 NVMe bring, the HPE ProLiant DL360 Gen10 means business. Deploy, update, monitor and maintain with ease by automating essential server life cycle management tasks with HPE OneView and HPE iLO 5. Deploy this 2P secure platform for diverse workloads in space constrained environments.
  • Industry-leading Performance with Versatile Compute
    HPE ProLiant DL360 Gen10 Server supports industry-standard technology leveraging the Intel Xeon Scalable processor with up to 28 cores, 12G SAS and 3.0 TB of 2666 MT/s HPE DDR4 SmartMemory.With support for up to 12 NVDIMMs per chassis and 2X capacity of first-generation HPE NVDIMMs, HPE ProLiant DL360 Gen10 Server delivers up to 192 GB per system.Achieve greater capacity with flexible drive configuration options with up to 10 SFF and four LFF drives along with an option to support up to 10 NVMe PCIe SSDs delivers enhanced performance, capacity, and reliability to meet various customer segments and workload requirements at the right economics.HPE Persistent Memory, the world's first non-volatile DIMM (NVDIMM) optimized on HPE ProLiant , offers up to 20X reduction in database restart time preserving maximum uptime.
  • Innovative Design for Flexibility and Choice
    The premium 10 SFF NVMe chassis backplane provides the ability to mix and match SAS/SATA and NVMe within the same chassis along with 8 + 2 SFF and 4 LFF chassis that supports new uFF and M.2 storage options.Embedded 4x 1GbE along with HPE FlexibleLOM or PCIe standup 1GbE, 10GbE, or 25GbE adapters provides flexibility of networking bandwidth and fabric so you can adapt and grow to changing business needs.Unmatched expandability is packed in a dense 1U rack design with up to three PCIe 3.0 slots.
  • Security Innovations
    HPE iLO 5 enables the world's most secure industry standard servers with HPE Silicon Root of Trust technology to protect your servers from attacks, detect potential intrusions and recover your essential server firmware securely.Millions of lines of firmware code run before the server OS boots and with Runtime Firmware Verification, enabled by HPE iLO Advanced Premium Security Edition, the server firmware is checked every 24 hours verifying validity and credibility of essential system firmware.Secure Recovery allows server firmware to roll back to the last known good state or factory settings after detection of compromised code.Additional security options are available with Trusted Platform Module (TPM) to prevent unauthorized access to server and securely stores artifacts used to authenticate the server platforms while the Intrusion Detection Kit logs and alerts when the server hood is removed.
  • Industry-Leading Serviceability and Deployment
    HPE ProLiant DL360 Gen10 Server comes with a complete set of services offered by HPE Pointnext, delivering confidence, reducing risk, and helping customers realize agility and stability.Services from HPE Pointnext simplifies the stages of the IT journey. Advisory and Transformation Services professionals understand customer challenges and design an enhanced solution. Professional Services enables rapid deployment of solutions and Operational Services provides ongoing support.Services provided under Operational Services include - HPE Flexible Capacity, HPE Datacenter Care, HPE Infrastructure Automation, HPE Campus Care, HPE Proactive Services and multi-vendor coverage.HPE IT investment solutions help you transform to a digital business with IT economics that align to your business goals.
HPE ProLiant DL360 Gen10 Performance - rack-mountable - Xeon Gold 5118 2.3 GHz - 32 GB
Server - rack-mountable
Height (Rack Units)
1U
Region: Worldwide
Server Scalability
2-way
2 x Intel Xeon Gold 5118 / 2.3 GHz (12-core)
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology
Cache Memory
33 MB L3 Cache
Cache Per Processor
16.5 MB
RAM
32 GB (installed) / 3 TB (max) - DDR4 SDRAM - PC4-20800
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8 (HPE Smart Array P408i-a); SATA (HPE Smart Array S100i SR Software)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Card Reader
Video Memory
16 MB
GigE, 10 GigE, 25 Gigabit LAN
Power Redundancy
43.46 cm x 70.7 cm x 4.29 cm
13.04 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site - response time: next business day , Technical support - software application support - 90 days
Server
Product Form Factor
Rack-mountable - 1U
Built-in Devices
Led panel, battery
Server Scalability
2-way
Hot-Swap Bays Qty
8
Region: Worldwide
Processor / Chipset
CPU
Number of Cores
12-core
CPU Qty
2
Max CPU Qty
2
CPU Upgradability
Upgradable
Chipset Type
Intel C621
Cache Memory
Installed Size
L3 Cache - 33 MB
Cache Per Processor
16.5 MB
RAM
Installed Size
32 GB / 3 TB (max)
DDR4 SDRAM
Effective Memory Speed
2400 MHz
Rated Memory Speed
2666 MHz
Memory Specification Compliance
PC4-20800
DIMM 288-pin
Slots
24 (Total) / 22 (empty)
Dual rank
Configuration Features
2 x 16 GB
RAM Supported
PC4-20800 - 3.072 TB Load-Reduced , PC4-20800 - 768 GB registered , PC4-20800 - 192 GB Non-Volatile
Hard Drive
No HDD
Storage Controller
1 x RAID - PCIe 3.0 x8
Controller Interface Type
Storage Controller Name
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60, RAID 1 ADM, RAID 10 ADM
Buffer Size
2 GB
Storage Controller (2nd)
SATA
Optical Storage
No optical drive
Card Reader
Card reader
Supported Flash Memory Cards
microSD
Monitor
Monitor Type
None.
Graphics Controller
Video Memory
16 MB
Video Interfaces
VGA
Interface (Bus) Type
FlexibleLOM
Ethernet Ports
4 x Gigabit Ethernet, 2 x 25 Gigabit Ethernet
Ethernet Controller
HP 640FLR
Ethernet, Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet, 25 Gigabit Ethernet
Remote Management Protocol
SNMP 3, IPMI 2.0, SMASH CLP
Remote Management Controller
Integrated Lights-Out 5
Wake on LAN (WoL), PXE support
Bays
1 (total) / 1 (free) x external Universal Media Bay , 8 (total) / 8 (free) x hot-swap 2.5" SFF
Slots
24 (total) / 22 (free) x DIMM 288-pin , 2 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe 3.0 x16 - three-quarter-length, full-height , 1 (total) / 0 (free) x PCIe 3.0 x8 - low-profile , 1 (total) / 0 (free) x FlexibleLOM - three-quarter-length, full-height (low-profile) , 1 (total) / 1 (free) x microSD Card (internal) , 1 (total) / 1 (free) x PCIe x16 - full-height
1 x HP iLO - Type A (1 in front) , 1 x HP iLO - RJ-45 (1 rear) , 5 x USB 3.0 (1 front, 2 rear, 2 internal) , 1 x VGA (1 rear) , 4 x LAN (Gigabit Ethernet) - RJ-45 (4 rear) , 2 x LAN (25Gigabit Ethernet) (SFP28) (2 rear)
HPE Easy Install Rails, HPE standard heatsink, 7 x standard hot plug fans
Power cable
AES, FIPS 140-2, IPv6 Ready, PCI DSS, TLS v1.2, FIPS 201 PIV, ASHRAE Class A4, ASHRAE Class A3, WEEE 2002/95/EC, ACPI 6.1
Power supply - hot-plug
Power Redundancy
Power Redundancy Scheme
1+1
Installed Qty
2
Max Supported Qty
2
Nominal Voltage
Power Provided
800 Watt
Operating System / Software
OS Certified
CentOS, Microsoft Windows Server 2012 R2, VMware vSphere 6.0 (ESXi), SuSE Linux Enterprise Server 11 SP4, Microsoft Windows Server 2016, Red Hat Enterprise Linux 7.3, Red Hat Enterprise Linux 6.9, VMware vSphere 6.5 (ESXi), SuSE Linux Enterprise Server 12 SP2, ClearOS
Software
HPE Server UEFI
ENERGY STAR Certified
ENERGY STAR Version
2.1
43.46 cm
70.7 cm
4.29 cm
13.04 kg
10 °C
35 °C
8 - 90% (non-condensing)
Sound Emission
38.1 dBA
HPE DL360 GEN10 5118 2P 32G 8FF Bundle deal on HPE DL360 GEN10 5118 2P 32G 8FF
£4,922.97
Type: Server
Case Style: Rack-mountable
Optical Storage: None
Brand: HPE
Price Range Ex VAT: 1500+
