Your basket is empty
HPE DL160 Gen8 E5-2620 Base EU Svr
Quicklinx: 888FWS00 Mfr#: 662083-421
  • Xeon
  • Red Hat Enterprise Linux
HP ProLiant DL160 Gen8, a dual-socket 1U rack server, provides high performance computing with increased manageability in affordable design. It is ideal for environments requiring high performance computing as well as for service providers with web serving, hosting, virtualization, and database needs.
HPE ProLiant DL160 Gen8 Base - Xeon E5-2620 2 GHz - 8 GB - 0 GB
Server - rack-mountable
Height (Rack Units)
1U
Europe
Server Scalability
2-way
1 x Intel Xeon E5-2620 / 2 GHz (2.5 GHz) (6-core)
Cache Memory
15 MB L3 Cache
Cache Per Processor
15 MB
RAM
8 GB (installed) / 384 GB (max) - DDR3 SDRAM - PC3-10600
Storage Controller
SATA (SATA 6Gb/s)
Server Storage Bays
Hot-swap 3.5"
Hard Drive
No HDD
Graphics Controller
Matrox G200
GigE
Power Redundancy
Optional
43.5 cm x 75 cm x 4.3 cm
14.1 kg
3 years warranty
Server
Recommended Use
Small business, corporate business
Product Form Factor
Rack-mountable - 1U
Server Scalability
2-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
4
Europe
Processor / Chipset
CPU
Max Turbo Speed
2.5 GHz
Number of Cores
6-core
64-bit Computing
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Chipset Type
Intel C600
Cache Memory
Installed Size
L3 Cache - 15 MB
Cache Per Processor
15 MB
RAM
Installed Size
8 GB / 384 GB (max)
DDR3 SDRAM
Effective Memory Speed
1333 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
DIMM 240-pin
Registered, quad channel memory architecture, HP SmartMemory
Configuration Features
2 x 4 GB
RAM Supported
PC3-12800 - 384 GB registered , PC3-10600 - 128 GB unbuffered
Hard Drive
No HDD
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Matrox G200
Video Interfaces
VGA
Input Device
Mouse, keyboard
Integrated
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
HP NC361i
Remote Management Controller
Integrated Lights-Out 4
Wake on LAN (WoL), PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3ad (LACP)
Bays
1 (total) / 1 (free) x external 5.25" Slim Line , 4 (total) / 4 (free) x hot-swap 3.5" LFF
Slots
24 (total) / 22 (free) x DIMM 240-pin , 2 (total) / 1 (free) x CPU , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x8 - low-profile
1 x serial , 2 x VGA (1 front, 1 rear) , 2 x LAN (Gigabit Ethernet) , 1 x HP iLO , 6 x USB 2.0 (2 front, 4 rear)
Administrator password, power-on password, keyboard password, serial port I/O control, quick lock
ACPI 2.0b, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, BSMI CNS 13438
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Nominal Voltage
Power Provided
500 Watt
80 PLUS Certification
80 PLUS Platinum
Operating System / Software
OS Certified
SuSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Solaris
Limited warranty - parts - 3 years - response time: next day
43.5 cm
75 cm
4.3 cm
14.1 kg
10 °C
35 °C
10 - 90% (non-condensing)
888F C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £4.26
888F C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.24
888F C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.42
888F C2G 2m Cat6a Shielded Patch - Blue In Stock £7.44
888F C2G TruLink Media Gateway RJ45 Cap In Stock £0.58
888F C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £47.13
