HPE DL160 Gen8 E5-2603 Entry EU Svr
Quicklinx: 88MHWS00 Mfr#: 662082-421
  • Xeon
  • Red Hat Enterprise Linux
HP ProLiant DL160 Gen8, a dual-socket 1U rack server, provides high performance computing with increased manageability in affordable design. It is ideal for environments requiring high performance computing as well as for service providers with web serving, hosting, virtualization, and database needs.
  • Unprecedented HPC and Hyperscale capabilities in an efficient design
    HPE SmartMemory improves workload performance and power efficiency while preventing data loss and downtime with enhanced error handling. Support for RDIMMs and UDIMMs with up to 768GB max capacity .HPE FlexibleLOM provides you additional choice of networking bandwidth and fabric so you can adapt to changing business needs.New generation of Smart Array RAID controller and support for HPE Smart Storage including PCIe 3.0, HPE SmartDrives, and HPE Flash Backed Write Cache with capacity up to 2GB. Choice of up to eight 2.5-inch SFF or four 3.5-inch LFF SAS, SATA, SSD drives with optical media.
  • Unlock your Infrastructure's Potential with HP's Easy-to-Use Integrated Management and Support
    HPE iLO Management Engine is a complete set of embedded features, standard on all ProLiant Gen8 servers. Includes HPE iLO, HPE Agentless Management, HPE Active Health System, HPE Intelligent Provisioning, and HPE Embedded Remote Support.HPE Insight Control provides advanced management capabilities across the lifecycle of your HPE ProLiant server infrastructure. HPE iLO Advanced, a key component, provides enhanced remote server functions that reduce IT travel costs, while increasing Time-To-Resolution.HPE Insight Online with HPE Insight Remote Support provides 24X7 remote monitoring and anywhere, anytime personalized access to your IT and support status.HPE SmartUpdate reduces deployment time and update complexity by systematically updating server infrastructure in the data center. Includes HPE Smart Update Manager (HPE SUM), and Service Pack for ProLiant (SPP), and other products.
  • Proactive Service and Support to Redefine Service Experience
    HPE Insight Online with HPE Insight Remote Support provides 24X7 remote monitoring and anywhere, anytime personalized access to your IT and support status.HPE proactive support services enable industry leading performance, uptime and productivity integrated into a personalized, simplified support experience.Through HPE ServiceOne partners, you get responsive qualified partners to help you plan, manage and deliver solutions spanning the entire IT lifecycle.User-inspired design features that prevent data loss, reduce downtime, and improve serviceability include HPE SmartDrives, HPE Smart Socket guides, "Snap and Go" rail kit options, and tool-less access to components.
  • Energy Efficiency Leadership
    Automated Energy Optimization reclaims space, power, and cooling resources needed for workloads and extends your data center capacity.High efficiency 80+ certified HPE Common Slot Power Supplies provide up to 94% efficiency (Platinum) and support HP's Power Discovery Services.Right-sized HPE ProLiant power supplies meet the exact needs, reclaiming lost data center power. Less oversubscription means more capacity opportunity. Be sure to use the HPE Power Adviser for selecting the right size power supply.ENERGY STAR qualified server configurations illustrate HP's continued commitment to helping customers conserve energy and save money.
HPE ProLiant DL160 Gen8 Entry - rack-mountable - Xeon E5-2603 1.8 GHz - 4 GB - no HDD
Server - rack-mountable - administrator password, power-on password, keyboard password, serial port I/O control, quick lock
Height (Rack Units)
1U
Region: Europe
Server Scalability
2-way
1 x Intel Xeon E5-2603 / 1.8 GHz (Quad-Core)
Cache Memory
10 MB L3 Cache
Cache Per Processor
10 MB
RAM
4 GB (installed) / 384 GB (max) - DDR3 SDRAM - PC3-10600
Storage Controller
SATA (SATA 6Gb/s)
Server Storage Bays
Hot-swap 3.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
Matrox G200
GigE
43.5 cm x 75 cm x 4.3 cm
14.1 kg
Limited warranty - parts - 3 years - response time: next day
Server
Recommended Use
Small business, corporate business
Product Form Factor
Rack-mountable - 1U
Server Scalability
2-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
4
Region: Europe
Processor / Chipset
CPU
Intel Xeon E5-2603
Clock Speed
1.8 GHz
Number of Cores
Quad-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Chipset Type
Intel C600
Cache Memory
Installed Size
L3 Cache - 10 MB
Cache Per Processor
10 MB
RAM
Installed Size
4 GB / 384 GB (max)
DDR3 SDRAM
Effective Memory Speed
1333 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
DIMM 240-pin
Slots
24 (Total) / 23 (empty)
Registered, quad channel memory architecture, HP SmartMemory
Configuration Features
1 x 4 GB
RAM Supported
PC3-12800 - 384 GB registered , PC3-10600 - 128 GB unbuffered
Hard Drive
No HDD
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Matrox G200
Video Interfaces
VGA
Input Device
Mouse, keyboard
Integrated
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
HP NC361i
Remote Management Controller
Integrated Lights-Out 4
Wake on LAN (WoL), PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3ad (LACP)
Bays
1 (total) / 1 (free) x external 5.25" Slim Line , 4 (total) / 4 (free) x hot-swap 3.5" LFF
Slots
24 (total) / 23 (free) x DIMM 240-pin , 2 (total) / 1 (free) x CPU , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x8 - low-profile
1 x serial , 2 x VGA (1 front, 1 rear) , 2 x LAN (Gigabit Ethernet) , 1 x HPE iLO , 6 x USB 2.0 (2 front, 4 rear)
Administrator password, power-on password, keyboard password, serial port I/O control, quick lock
ACPI 2.0b, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, BSMI CNS 13438
Power supply
Installed Qty
1
Power Provided
500 Watt
80 PLUS Certification
80 PLUS Platinum
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Solaris
43.5 cm
75 cm
4.3 cm
14.1 kg
10 °C
35 °C
10 - 90% (non-condensing)
88MH C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
