Product
Brand
HPE DDR3 16 GB DIMM 240-pin 1600 MHz / PC3-12800
Quicklinx: CZ3KWS00 Mfr#: 672633-B21
There are many demands on your server…is it performing reliably and efficiently? When you choose HPE DDR3 SmartMemory, you get significant data transfer speed and capacity improvements over older DDR technologies, backed by our industry-leading reliability. All of our SmartMemory goes through rigorous modeling, qualification and testing processes that unlock extended memory performance features. This extensive testing ensures that your HPE server memory is completely compatible with and optimized for your HPE server. HPE servers configured with HPE DDR3 SmartMemory deliver extended performance and manageability in a number of configurations that is not supported using third-party DIMMs.
HPE - DDR3 - 16 GB - DIMM 240-pin
RAM memory
16 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Dual rank, registered
Pricing Type
Factory integrated
16 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11
ECC
Chips Organization
X4
Compatible Slots
1 x memory - DIMM 240-pin
Pricing Type
Factory integrated
