The HP ProLiant BL460c Gen8 Server Blade is a dual-socket server blade engineered for unprecedented performance, enhanced flexibility and simplified management which makes it the standard for data center computing. It packs in more performance with a 33% increase in memory DIMM count, Intel Xeon E5-2600 v2 Processors, faster I/O slots and enhanced Smart Array Controller that now ships with 512MB Flash Back Write Cache standard. In addition, it is also more flexible with the HP FlexibleLOM which provides the ability to customize server networking today and the ability to meet future needs without overhauling server hardware.
Redefining the Customer Experience
User-inspired design features like HPE SmartDrive carriers and the HPE Smart Socket guide anticipate your needs and virtually eliminate common issues that result in downtime.Integrated Lifecycle Automation, an industry first, provides embedded provisioning tools, Active Health monitoring, and system maintenance capabilities standard on all ProLiant servers using the industry-leading HPE iLO Management Engine.Dynamic Workload Acceleration delivers smarter data protection for ever-increasing drive capacities, real-time workload-aware analysis to optimize and adapt storage performance, and 6X faster solid state performance versus previous generation.Automated Energy Optimization improves the server's ability to analyze and respond to "3D sea of sensors" data within the server as well as self-identify location and inventory through Insight Control for maximum workload optimization across the entire datacenter. -
Intuitive, Configurable Management System Eliminates Tedious, Time-Consuming Tasks
HPE Intelligent Provisioning takes strengths from products like HPE SmartStart, HPE Smart Update Manager and HPE Service Pack for ProLiant, enhances them with the latest ease of use features, and places them where you can use them instantly - on the system board.Agentless hardware monitoring and alerting capabilities are built into the server with HPE Agentless Management (runs on the iLO 4 chipset). Starts working the moment that a power cord and an Ethernet cable is connected to the enclosure.HPE Active Health System provides 24x7 continuous health monitoring, 100% configuration change logging, and faster problem analysis with HPE Service and Support. Start problem analysis 5x faster using unified diagnostic tools with secure data transfer to HPE Service and Support. -
Improved Application, Storage, and I/O Performance
HPE SmartMemory has unmatched performance, quality and manageability advantages above industry standard memory. Supports RDIMM, UDIMM and LRDIMM with up to 512GB capacity and 256GB capacity at 1866MHz. SmartMemory in the BL460c Gen8 delivers up to 33% more memory capacity over previous generations.Embedded Smart Array P230i (HPE Secure Encryption capable) or P220i RAID controller with 512MB Flash Backed Write Cache standard. Support for HPE Smart Storage and HPE SmartDrives. Choice of two (2) 2.5-inch SFF SAS, SATA, SSD drives.PCIe 3.0 technology provides improved latency and up to 400% the bandwidth per I/O expansion slot compared to ProLiant BL460c G7.Two x16 PCIe 3.0 I/O expansion slots support the highest performing mezzanine option cards now and into the future.HPE FlexibleLOM provides the ability to customize server networking today and the ability to meet future needs without overhauling server hardware. Provides choice of bandwidth and fabric (Ethernet, FCoE, InfiniBand), supports WOL, and provides a shared iLO port for ease of use. -
Built for Performance and Easier Access
Improved access to mezzanine cards enables quicker removal and easy access to the new FlexibleLOM card. The DIMM tool included inside every ProLiant BL460c Gen8 makes the removal and insertion of individual DIMMs even easier.Intel Xeon E5-2600 v2 Processor Family offers higher performance, power efficiency, more adaptability, and enhanced security with Intel QuickPath, Integrated Memory Controller, Turbo Boost ,Intelligent Power Technologies, Intel Secure Key, Intel OS Guard, and Floating Point Bit Depth Conversion.Expanded memory options now include the HPE 24GB (1x24GB) Three Rank x4 PC3L-10600R (DDR3-1333) Registered Low Voltage FIO Memory Kit.
- HPE ProLiant BL460c Gen8 - blade - Xeon E5-2650V2 2.6 GHz - 32 GB - no HDD
- Server - blade - administrator password, power-on password, keyboard password, USB port control, quick lock
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5-2650V2 / 2.6 GHz (3.4 GHz) (8-core)
- Processor Main Features
- Hyper-Threading Technology, Intel QuickPath Interconnect, Intel Turbo Boost Technology 2
- Cache Memory
- 20 MB L3 Cache
- Cache Per Processor
- 20 MB
- RAM
- 32 GB (installed) / 256 GB (max) - DDR3 SDRAM - PC3-14900
- Storage Controller
- SAS-2 (SAS 6Gb/s) - PCIe x4 (Smart Array P220i with 512MB FBWC)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Matrox G200
- Networking
- GigE, 10 GigE, FCoE
- 5.54 cm x 51.76 cm x 18.07 cm
- 4.75 kg
- Limited warranty - parts and labour - 3 years - on-site
- Server
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Blade
- 2-way
- Hot-Swap Bays Qty
- 2
Processor / Chipset
- CPU
- Intel Xeon E5-2650V2
- Clock Speed
- 2.6 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- 8-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
Cache Memory
- Installed Size
- L3 Cache - 20 MB
- 20 MB
RAM
- Installed Size
- 32 GB / 256 GB (max)
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1866 MHz
- Rated Memory Speed
- 1866 MHz
- Memory Specification Compliance
- PC3-14900
- Form Factor
- DIMM 240-pin
- Slots
- 16 (Total) / 14 (empty)
- Registered, HP SmartMemory
- Configuration Features
- 2 x 16 GB
- RAM Supported
- PC3-14900 - 256 GB registered , PC3-14900 - 128 GB unbuffered - Advanced ECC , PC3-14900 - 512 GB - low voltage - Load-Reduced , PC3-10600 - 384 GB - low voltage - registered , PC3-12800 - 128 GB - low voltage - unbuffered - Advanced ECC , PC3-12800 - 256 GB - low voltage - registered
Hard Drive
- No HDD
Storage Controller
- 1 x SAS-2 - integrated - PCIe x4
- Controller Interface Type
- SAS 6Gb/s
- Storage Controller Name
- Smart Array P220i with 512MB FBWC
- RAID Level
- RAID 0, RAID 1
- Buffer Size
- 512 MB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Matrox G200
- Plug-in card
- Interface (Bus) Type
- PCI Express 2.0 x8
- Ethernet Ports
- 2 x 10 Gigabit Ethernet
- Ethernet Controller
- HP 534FLB
- Data Link Protocol
- Gigabit Ethernet, 10 Gigabit Ethernet, Fibre Channel over Ethernet (FCoE)
- Remote Management Protocol
- SNMP, IPMI 2.0, SMASH CLP
- Remote Management Controller
- Integrated Lights-Out 4
- Bays
- 2 (total) / 2 (free) x hot-swap 2.5" SFF
- Slots
- 2 (total) / 1 (free) x CPU , 16 (total) / 14 (free) x DIMM 240-pin , 2 (total) / 2 (free) x expansion slot (x16 mode) , 1 (total) / 1 (free) x microSDHC Card (internal) , 1 (total) / 0 (free) x FlexibleLOM
- 1 x USB 2.0 (1 internal)
- Administrator password, power-on password, keyboard password, USB port control, quick lock
- ACPI 2.0, WEEE
Operating System / Software
- OS Certified
- SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Solaris, Citrix XenServer, Canonical Ubuntu
- 5.54 cm
- 51.76 cm
- 18.07 cm
- 4.75 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
