Do your servers need high-performance SAS disk drives for both your mission-critical and storage driven applications? HPE SAS Hard Drives for enterprise and midline applications deliver high-performance solutions for hosting high transaction based applications. They are available in HPE Smart Carrier, HPE Standard Hot Plug Carrier and HPE Non-hot Plug Carrier. HPE SAS Hard Drives are available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) and come in a variety of capacity points to meet a wide range of requirements supporting enterprise and midline applications. The SAS interface was specifically engineered to deliver high availability where enterprise-class data storage, performance, reliability and data integrity are crucial.
Performance and Reliability for Multiple Application Environments
HPE Server Enterprise Hard Drives are ideal for transaction processing, database applications, big data analytics and high-performance computing.Broad portfolio of optimized solutions provide up to 1.8 TB of storage in a smaller footprint.Efficient drives for power and space constrained datacenters.Latest 12G SAS interface for increased performance.
- HPE Enterprise - hard drive - 900 GB - SAS 12Gb/s
- Hard drive - hot-swap
- Capacity
- 900 GB
- Form Factor
- 2.5"
- Interface
- SAS 12Gb/s
- Data Transfer Rate
- 1.2 GBps
- Spindle Speed
- 10000 rpm
- Bundled with
- HP SmartDrive carrier
- Designed For
- Apollo 4200 Gen9; Nimble Storage dHCI Large Solution with HPE ProLiant DL380 Gen10; ProLiant BL460c Gen10, BL465c Gen8, BL660c Gen9, DL120 Gen9, DL180 Gen9, DL20 Gen9, DL320e Gen8, DL360 Gen10, DL380 Gen10, DL388 Gen10, DL388 Gen9, DL560 Gen9, DL580 Gen9, ML110 Gen9, ML310e Gen8, ML350e Gen8, XL230a Gen9, XL250a Gen9; Synergy 480 Gen10, 660 Gen10
- Capacity
- 900 GB
- Form Factor
- 2.5"
- Interface
- SAS 12Gb/s
- Bundled with
Performance
- Drive Transfer Rate
- 1.2 GBps (external)
- Spindle Speed
- 10000 rpm
Expansion & Connectivity
- 1 x SAS 12 Gb/s
- Compatible Bay
- 2.5"
- Designed For
- HPE Apollo 4200 Gen9 for Google (2.5") , HPE Nimble Storage dHCI Large Solution with HPE ProLiant DL380 Gen10 (2.5") , HPE ProLiant BL460c Gen10 (2.5"), BL660c Gen9 (2.5"), DL20 Gen9 (2.5"), DL20 Gen9 Entry (2.5"), DL20 Gen9 Performance (2.5"), DL360 Gen10 Base (2.5"), DL360 Gen10 Entry (2.5"), DL360 Gen10 High Performance (2.5"), DL360 Gen10 Low (2.5"), DL360 Gen10 Performance (2.5"), DL360 Gen10 SMB (2.5"), DL360 Gen10 Solution (2.5"), DL380 Gen10 (2.5"), DL380 Gen10 Base (2.5"), DL380 Gen10 Entry (2.5"), DL380 Gen10 Entry SMB (2.5"), DL380 Gen10 for Cohesity DataPlatform (2.5"), DL380 Gen10 for SAP HANA Compute Block (2.5"), DL380 Gen10 High Performance (2.5"), DL380 Gen10 Network Choice (2.5"), DL380 Gen10 Network Choice for SAP HANA Compute Block (2.5"), DL380 Gen10 Performance (2.5"), DL380 Gen10 Server for CTERA (2.5"), DL380 Gen10 SMB (2.5"), DL380 Gen10 Solution (2.5"), DL388 Gen10 (2.5"), DL388 Gen9 (2.5"), DL388 Gen9 Base (2.5"), DL560 Gen9 (2.5"), DL560 Gen9 Base (2.5"), DL560 Gen9 Entry (2.5"), DL560 Gen9 Performance (2.5"), DL580 Gen9 (2.5"), DL580 Gen9 Database (2.5"), DL580 Gen9 SAP HANA Scale-out Base Configuration (2.5"), DL580 Gen9 SAP HANA Scale-up Base Configuration (2.5"), ML110 Gen9 Base (2.5"), ML110 Gen9 Entry (2.5"), XL230a Gen9 Compute Tray (2.5"), XL230a Gen9 Compute Tray (12G) (2.5"), XL230a Gen9 Compute Tray (6G) (2.5"), XL230a Gen9 NHP Compute Tray (12G) (2.5" SFF), XL250a Gen9 Accelerator Tray (2.5") , HPE Synergy 480 Gen10 Base Compute Module (2.5"), 480 Gen10 Entry Compute Module (2.5"), 480 Gen10 Performance Compute Module (2.5"), 480 Gen10 Premium Backplane Compute Module (2.5"), 480 Gen10 Standard BackPlane Compute Module (2.5"), 480 Gen10 w/o Drives Compute Module (2.5"), 660 Gen10 Base Compute Module (2.5"), 660 Gen10 Compute Module (2.5"), 660 Gen10 Entry Compute Module (2.5"), 660 Gen10 Performance Compute Module (2.5"), 660 Gen10 Premium Compute Module (2.5")
