Your basket is empty
HPE 8GB microSD Enterprise Mainstream Flash Media Kit
Quicklinx: BX71WS00 Mfr#: 726116-B21
HP provides several high performance Flash Media kits for customers who require boot from flash solutions. Form factors include USB Key, SD Card and MicroSD Card allowing the flexibility to support VMWare Hypervisors and direct OS boot for Windows2012 Server and Linux across HP ProLiant portfolio. HP Flash Media kits optimized for VMWare Hypervisors: - HP 2GB USB Flash Media Drive Key Kit - HP 4GB SD Enterprise Performance Flash Media Kit - HP 4GB microSD Enterprise Performance Flash Media Kit - HP 8GB SD Enterprise Mainstream Flash Media Kit - HP 8GB microSD Enterprise Mainstream Flash Media Kit HP Flash Media kits optimized for Windows2012 and Linux boot: - HP 32GB SD Enterprise Mainstream Flash Media Kit - HP 32GB microSD Enterprise Mainstream Flash Media Kit.
HPE Enterprise Mainstream Flash Media Kit - flash memory card - 8 GB - microSD
Flash memory card
microSD
Storage Capacity
8 GB
Speed Rating
Class 10
MLC NAND Flash
Supply Voltage
2.7 - 3.6 V
Linux, Ubuntu 12.04, SuSE Linux Enterprise Server 11 SP2, Microsoft Windows Server 2012 Standard, Microsoft Windows Server 2012 Datacenter, Red Hat Enterprise Linux 6.3
ProLiant BL420c Gen8, BL460c Gen10, BL460c Gen8, BL465c Gen8, BL620C G7, BL660c Gen8, DL320e Gen8, DL360 Gen10, DL560 Gen8, MicroServer Gen8, ML10 v2, ML310e Gen8, SL230s Gen8, SL250s Gen8, SL270s Gen8, XL220a Gen8, XL750f Gen9; Synergy 480 Gen10, 480 Gen9, 620 Gen9, 660 Gen10, 660 Gen9, 680 Gen9
Flash memory card
Storage Capacity
8 GB
Compatibility
Non-specific
SD Speed Class
Class 10
Read Rate
Up to 21 MB/s
Write Rate
Up to 17 MB/s
microSD
MLC NAND Flash
Supply Voltage
2.7 - 3.6 V
WEEE
11 mm
15 mm
Thickness
0.95 mm
70 °C
HPE ProLiant BL420c Gen8, BL460c Gen10, BL460c Gen8, BL465c Gen8, BL660c Gen8, BL660c Gen8 Performance, DL320e Gen8, DL320e Gen8 Base, DL320e Gen8 Entry, DL320e Gen8 Performance, DL320e Gen8 v2, DL320e Gen8 v2 Base, DL320e Gen8 v2 Performance, DL360 Gen10, DL360 Gen10 Base, DL360 Gen10 Entry, DL360 Gen10 High Performance, DL360 Gen10 Performance, DL560 Gen8, DL560 Gen8 Base, DL560 Gen8 Entry, DL560 Gen8 Performance, MicroServer Gen8, MicroServer Gen8 Base, MicroServer Gen8 Base Starter Kit, MicroServer Gen8 Entry, ML10 v2, ML10 v2 Base, ML10 v2 Entry, ML10 v2 Performance, ML310e Gen8, ML310e Gen8 Base, ML310e Gen8 Entry, ML310e Gen8 Performance, ML310e Gen8 v2, ML310e Gen8 v2 Base, ML310e Gen8 v2 Enty, ML310e Gen8 v2 Performance, SL230s Gen8 1U Left Half Width Tray, SL250s Gen8 2U PCIe Gen3 Left Tray, SL250s Gen8 2U PCIe Gen3 Right Tray, SL250s Gen8 Base 2U Left Half Width Tray, SL250s Gen8 Base 2U Right Half Width Tray, SL270s Gen8 1U Left Half Width Tray, SL270s Gen8 1U Right Half Width Tray, SL270s Gen8 Base 4U Left Half Width Tray, SL270s Gen8 Base 4U Right Half Width Tray, SL270s Gen8 SE 4U Left Tray, SL270s Gen8 SE 4U Right Tray, XL220a Gen8 v2, XL750f Gen9 , HPE Synergy 480 Gen10 Base Compute Module, 480 Gen10 Entry Compute Module, 480 Gen10 Performance Compute Module, 480 Gen10 Premium Backplane Compute Module, 480 Gen10 Standard BackPlane Compute Module, 480 Gen10 w/o Drives Compute Module, 480 Gen9 Compute Module, 620 Gen9 2S-EX Base Compute Module, 620 Gen9 2S-EX Performance Compute Module, 660 Gen10 Base Compute Module, 660 Gen10 Compute Module, 660 Gen10 Entry Compute Module, 660 Gen10 Performance Compute Module, 660 Gen10 Premium Compute Module, 660 Gen9 Base Compute Module, 660 Gen9 Compute Module, 660 Gen9 Entry Compute Module, 660 Gen9 Expanded Storage Compute Module, 660 Gen9 Performance Compute Module, 680 Gen9 4S-EX Base Compute Module, 680 Gen9 4S-EX Performance Compute Module
