HPE 8GB 1RX8 PC4-2400T-E kit
Quicklinx: DTLGWS00 Mfr#: 862974-b21
Type: DDR4 SDRAM
Capacity: 8GB
Connection: DIMM 288-pin
Speed: 2400MHz
Registered/Buffered: Unbuffered
£89.76 ex VAT
£107.71 inc VAT
Small and medium business owners often must choose between the need for high-performance server memory that supports their workloads and the simultaneous desire to control capital and operating expenses. With HPE DDR4 Standard Memory, you don't need to choose between performance and cost efficiency. Unlike third-party alternatives, HPE Standard Memory is sourced from the highest-quality DRAMS and undergoes a rigorous testing and authentication process. This extensive testing ensures that it is completely compatible with and optimized for entry-level HPE server platforms to perform to industry-defined specifications.
HPE - DDR4 - 8 GB - DIMM 288-pin - unbuffered
RAM memory
8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17 (17-17-17)
Single rank, unbuffered
Voltage
1.2 V
HP 862974-B21
ProLiant DL20 Gen9, MicroServer Gen10, ML30 Gen9
8 GB
Upgrade Type
System specific
HP 862974-B21
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL17 (17-17-17)
ECC
Chips Organization
X8
Voltage
1.2 V
HPE ProLiant DL20 Gen9, DL20 Gen9 Base, DL20 Gen9 Entry, DL20 Gen9 Performance, DL20 Gen9 Solution, DL20 Gen9 Special Server, MicroServer Gen10, MicroServer Gen10 Entry, MicroServer Gen10 Performance, MicroServer Gen10 Solution, ML30 Gen9, ML30 Gen9 Base, ML30 Gen9 Entry, ML30 Gen9 Performance, ML30 Gen9 Solution
Type: DDR4 SDRAM
Capacity: 8GB
Speed: 2400MHz
Brand: HPE
Price Range Ex VAT: 50 - 100
