Is finding reliable DRAM memory for your HP ProLiant Gen8 Server series in your data center a major challenge? When you choose HP SmartMemory you get the same high quality, reliability, and confidence that come with your HP ProLiant Gen8 Server series. DRAM quality and reliability are more important now than ever. Industry trends such as server virtualization, cloud computing, the use of large database applications, and high-performance computing have all created demand for higher capacity memory with greater reliability and uptime. HP SmartMemory unlocks certain features available only with HP Qualified Server memory. HP SmartMemory enables ProLiant Gen8 Servers to reliably identify and verify whether installed memory has passed the rigorous HP qualification and testing processes. And because the memory is authenticated, you can enable extended memory performance features through the system ROM.
High Performance
HPE DDR3 SmartMemory performs to industry-defined specifications.HPE DDR3 SmartMemory has been tested and performance-tuned specifically for HPE ProLiant Server series, which ensures that HPE server memory is optimized for every HPE server.HPE DDR3 SmartMemory enables extended memory performance features through the system ROM. -
High Reliability
HPE DDR3 SmartMemory is made of the highest quality materials, reducing issues that affect signal integrity and increasing system reliability. -
Improved Efficiency
HPE DDR3 SmartMemory supports HPE servers at a lower price point.
- HPE - DDR3L - module - 8 GB - DIMM 240-pin - 1600 MHz / PC3L-12800 - registered
- Product Type
- Memory module
- Capacity
- 8 GB
- Memory Type
- DDR3L SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 1600 MHz (PC3L-12800)
- Latency Timings
- CL11
- Single rank, Low Voltage, registered
- Voltage
- 1.35 V
- Designed For
- ProLiant BL460c Gen8, BL660c Gen8, DL360p Gen8, DL380p Gen8, DL388p Gen8, DL560 Gen8, ML350p Gen8, SL230s Gen8, SL250s Gen8, SL270s Gen8, SL4540 Gen8, WS460c Gen8
- Capacity
- 8 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR3L SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- CL11
- ECC
- Chips Organization
- X4
- Voltage
- 1.35 V
- Compatible Slots
- 1 x memory
- Designed For
- HPE ProLiant BL460c Gen8, BL660c Gen8, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL360p Gen8 Performance, DL360p Gen8 Special Server, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Performance, DL380p Gen8 Special, DL388p Gen8 Base, DL560 Gen8 Performance, ML350p Gen8, ML350p Gen8 Base, ML350p Gen8 Entry, ML350p Gen8 Performance, ML350p Gen8 Special Server, SL230s Gen8 1U Left Half Width Tray, SL230s Gen8 1U Right Half Width Tray, SL230s Gen8 Base 1U Left Tray Server, SL230s Gen8 Base 1U Right Tray Server, SL250s Gen8 2U Left Half Width Tray, SL250s Gen8 2U PCIe Gen3 Left Tray, SL250s Gen8 2U PCIe Gen3 Right Tray, SL250s Gen8 2U Right Half Width Tray, SL250s Gen8 Base 2U Left Half Width Tray, SL250s Gen8 Base 2U Left Tray Server, SL250s Gen8 Base 2U Right Half Width Tray, SL250s Gen8 Base 2U Right Tray Server, SL250s Gen8 Left Tray, SL250s Gen8 Right Tray, SL270s Gen8 1U Left Half Width Tray, SL270s Gen8 1U Right Half Width Tray, SL270s Gen8 Base 4U Left Half Width Tray, SL270s Gen8 Base 4U Right Half Width Tray, SL270s Gen8 SE 4U Left Tray, SL270s Gen8 SE 4U Right Tray, SL4540 Gen8 Tray 1x Node Server, SL4540 Gen8 Tray 3x Node Server, WS460c Gen8
