HP StorageWorks 81B PCI-e Fiber Channel Host Bus Adapter Dual Port delivers twice the performance of 4Gbps HBAs for enterprises looking for SAN connectivity solutions to have unmatched performance, reliability, and server utilization.
HP StorageWorks 8Gbps PCI-e Fiber Channel Host Bus Adapters brings datacenter infrastructure components to a higher level of performance and efficiency with the ability to deliver twice the I/O performance of 4Gbps HBAs. An 8Gbps FC HBA purchased today is backward compatible with 4 and 2Gbps storage networks and will protect future investments. When using storage intensive applications, such as backup/restore, database transactions, virtualization, and rich media, the increased performance of the 8Gbps infrastructure enables more rapid storage and retrieval of critical information.
Finally, 8Gb PCI-e FC Host Bus Adapters provide a number of features that work together to reduce power consumption, thus delivering a "green" benefit within the server.
Greater performance
The PCIe 8Gb Fiber Channel Host Bus Adapters deliver twice the I/O performance of 4Gb HBAs. -
Positioned for the future
Moving to 8Gbps technology provides the infrastructure required for the more powerful servers and data intensive applications of the future. -
Enhanced for storage intensive applications
When using storage intensive applications like backup/restore, database transactions, virtualization and rich media, the improved I/O performance enables faster storage and retrieval of data. -
Powered for virtualized servers
It is ideal for the implementation of virtual servers with the power to drive multiple virtual machines. -
N Port ID Virtualization support
Allow a single port to acquire multiple N Port IDs, eliminating the need for additional physical ports. -
Queue prioritization
Datacenter administrators do not need to concern themselves with multiple requests from the virtualized servers potentially creating conflict. -
Supports virtualized servers for overall effective server utilization
It is ideal for the implementation of virtual servers, with the capability for migrating guest Operating Systems. And (Qlogic) Functional Level Reset (FLR) provides the ability to reset a port in a dual port configuration without impact to the other port.
- HPE StorageWorks 81B - host bus adapter - PCIe - Fibre Channel
- Host bus adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express
- Ports
- Fibre Channel
- 16.8 cm x 6.9 cm
- Data Link Protocol
- 8Gb Fibre Channel
- System Requirements
- Linux, Microsoft Windows Server 2003, Red Hat Enterprise Linux 5 for Intel x86 / AMD64 / EM64T, Red Hat Enterprise Linux 5.1 for Intel x86 / AMD64 / EM64T, SuSE Linux Enterprise Server 10 SP1
- Designed For
- ProLiant DL120 G7, DL160 Gen8, DL165 G7, DL360 G7, DL370 G6, DL380 G6, DL380 G7, DL385p Gen8, DL580 G5, DL980 G7, SL160s G6; StorageWorks MSL2024, MSL4048; StorageWorks 1/8 G2 Tape Autoloader; StorageWorks Network Storage Gateway X3400 G2, X3800 G2; StorageWorks Network Storage System X1600, X1800
- Host bus adapter
- Form Factor
- PCI Express
- Ports
- Fibre Channel
- Connectivity Technology
- Wired
- 8Gb Fibre Channel
- 1 x Fibre Channel - LC - x 2
- Compatible Slots
- 1 x PCI Express
- Included Accessories
- Low-profile bracket
- OS Required
- 16.8 cm
- 6.9 cm
- 0 °C
- 55 °C
- 10 - 90%
- Designed For
- HPE ProLiant DL120 G7, DL120 G7 Base, DL120 G7 Entry, DL120 G7 Performance, DL160 G6 Special Server, DL160 Gen8, DL160 Gen8 Entry, DL160 Gen8 Performance, DL160se G6, DL165 G6, DL165 G7, DL165 G7 Base, DL165 G7 Performance, DL165 G7 Special Server, DL180 G6 Special Server, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Central Management Server, DL360 G7 Efficiency, DL360 G7 Entry, DL360 G7 Performance, DL360 G7 Special Server, DL370 G6 High Performance, DL380 G6, DL380 G7, DL380 G7 Base, DL380 G7 Efficiency, DL380 G7 Entry, DL380 G7 Performance, DL380 G7 Special Server, DL385 G6, DL385 G6 Base, DL385 G6 Entry, DL385 G6 High Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 HE, DL385 G7 Performance, DL385p Gen8, DL385p Gen8 Dedicated Workload, DL385p Gen8 Entry, DL385p Gen8 Maximized Consolidation, DL385p Gen8 Storage, DL580 G5 Highly Serviceable Tower, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G7, DL585 G7 Base, DL585 G7 Performance, DL785 G6, DL785 G6 Base, DL785 G6 Performance, DL980 G7, ML350 G6 Special Server, SL160s G6 , HPE StorageWorks 8/8 (8) Full Fabric Ports Enabled SAN Switch, 8/8 Base (0) e-port SAN Switch, MSL2024 Ultrium 3000, MSL2024 Ultrium 3280, MSL4048 Ultrium 3000, MSL4048 Ultrium 3280, MSL8096 Ultrium 3280, SN6000C 16-ports Active Fabric Switch, SN6000C 32-ports Active Fabric Switch , HPE StorageWorks 1/8 G2 Tape Autoloader Ultrium 3000 , HPE StorageWorks Modular Smart Array P2000 G3 FC Dual Controller LFF Array , HPE StorageWorks Network Storage Gateway X3400, X3400 G2, X3800, X3800 G2 , HPE StorageWorks Network Storage System X1400 2TB SATA Model, X1400 4TB SATA Model, X1600, X1600 12TB SATA Model, X1600 292GB SAS Model, X1600 5.4TB SAS Model, X1600 6TB SATA Model, X1600 7.5TB SAS Model, X1800, X1800 2.4TB SAS Model, X1800 292GB SAS Model, X1800 3.6TB SAS Model, X1800 6TB SATA Model
