HPE 8-port 10GBASE-T v2 zl Module
Quicklinx: 80QDWS00 Mfr#: J9546A
Type: Modules
£2,996.38 ex VAT
£3,595.65 inc VAT
HP 8-port 10GBase-T v2 zl Module is for medum distance (upto 100m) 10G connectivity without the need for transceivers, using existing cabling infrastructure.
  • Application/Usage Data Networking
  • Interfaces/Ports 8 x 10Base-T LAN
  • Interfaces/Ports Details 8 x RJ-45 10Base-T Network LAN
Dimensions (W x D x H)
10.3 x 8.13 x 1.75 in. (26.16 x 20.65 x 4.45 cm)
HPE - expansion module
Expansion module
Plug-in module
Ports
10Gb Ethernet x 8
Cabling Type
Ethernet 10GBase-T
10 GigE
Data Transfer Rate
10 Gbps
HPE 8206, 8206-44G-PoE+/2XG-SFP+ v2, 8212, 8212-92G-PoE+/2XG-SFP+ v2; HPE Aruba 5406, 5406-44G-PoE+/4SFP, 5406-44G-PoE+-2XG v2, 5406-48G, 5412, 5412-92G-PoE+/4SFP, 5412-92G-PoE+-2XG v2, 5412-92G-PoE+-4G v2, 5412-96G
Expansion module
Plug-in module
Ports
10Gb Ethernet x 8
Wired
Cabling Type
Ethernet 10GBase-T
10 Gigabit Ethernet
Data Transfer Rate
10 Gbps
8 x 10GBase-T - RJ-45
Compatible Slots
1 x Expansion Slot
HPE 8206 zl Switch, 8206-44G-PoE+/2XG-SFP+ v2 zl Switch, 8212 zl Switch, 8212-92G-PoE+/2XG-SFP+ v2 zl Switch , HPE Aruba 5406 zl, 5406-44G-PoE+/4SFP Rack Shippable zl Switch, 5406-44G-PoE+/4SFP zl, 5406-44G-PoE+-2XG v2 zl, 5406-48G Rack Shippable zl, 5406-48G zl, 5412 zl, 5412-92G-PoE+/4SFP Rack Shippable zl, 5412-92G-PoE+/4SFP zl, 5412-92G-PoE+-2XG v2 zl, 5412-92G-PoE+-4G v2 zl, 5412-96G zl
80QD C2G 2m Cat6a Shielded Patch - Blue In Stock £6.96
Type: Modules
Brand: HPE
Price Range Ex VAT: 1500+
