Do your servers need high-performance SAS disk drives for both your mission-critical and storage driven applications? HPE SAS Hard Drives for enterprise and midline applications deliver high-performance solutions for hosting high transaction based applications. They are available in HPE Smart Carrier, HPE Standard Hot Plug Carrier and HPE Non-hot Plug Carrier. HPE SAS Hard Drives are available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) and come in a variety of capacity points to meet a wide range of requirements supporting enterprise and midline applications. The SAS interface was specifically engineered to deliver high availability where enterprise-class data storage, performance, reliability and data integrity are crucial.
Performance and Reliability for Multiple Application Environments
HPE Server Enterprise Hard Drives are ideal for transaction processing, database applications, big data analytics and high-performance computing.Broad portfolio of optimized solutions provide up to 1.8 TB of storage in a smaller footprint.Efficient drives for power and space constrained datacenters.Latest 12G SAS interface for increased performance.
- HPE Enterprise - hard drive - 600 GB - SAS 12Gb/s
- Hard drive - hot-swap
- Capacity
- 600 GB
- Form Factor
- 2.5" SFF
- Interface
- SAS 12Gb/s
- Data Transfer Rate
- 1.2 GBps
- Spindle Speed
- 15000 rpm
- 78.7 mm x 138.4 mm x 16 mm
- 450 g
- 3-year warranty
- Bundled with
- HP SmartDrive carrier
- Designed For
- Apollo 4200 Gen9; ProLiant BL420c Gen8, BL460c Gen10, BL460c Gen8, BL465c Gen8, BL660c Gen9, DL180 Gen9, DL20 Gen9, DL320e Gen8, DL360 Gen9, DL360p Gen8, DL380 Gen9, DL380e Gen8, DL380p Gen8, DL385p Gen8, DL388 Gen9, DL388p Gen8, DL560 Gen8, DL560 Gen9, DL580 Gen8, DL580 Gen9, ML110 Gen9, ML30 Gen9, ML350 Gen9, ML350p Gen8, WS460c Gen9, XL170r Gen9, XL190r Gen9, XL230a Gen9, XL250a Gen9
- Capacity
- 600 GB
- Form Factor
- 2.5" SFF
- Interface
- SAS 12Gb/s
- Bytes per Sector
- 512
- 78.7 mm
- 138.4 mm
- 16 mm
- 450 g
- Bundled with
Performance
- Drive Transfer Rate
- 1.2 GBps (external)
- Seek Time
- 2.9 ms (average) / 5.9 ms (max)
- Track-to-Track Seek Time
- 0.15 ms
- Spindle Speed
- 15000 rpm
Expansion & Connectivity
- 1 x SAS 12 Gb/s
- Compatible Bay
- 2.5" SFF
- WEEE
- Limited warranty - 3 years
- 10 °C
- 35 °C
- Designed For
- HPE Apollo 4200 Gen9 for Google (2.5") , HPE ProLiant BL460c Gen10 (2.5"), BL460c Gen8 (2.5"), BL660c Gen9 (2.5"), DL180 Gen9 (2.5"), DL180 Gen9 Base (2.5"), DL180 Gen9 Entry (2.5"), DL180 Gen9 Storage (2.5"), DL20 Gen9 (2.5"), DL20 Gen9 Entry (2.5"), DL20 Gen9 Performance (2.5"), DL320e Gen8 (2.5"), DL320e Gen8 Base (2.5"), DL320e Gen8 Entry (2.5"), DL320e Gen8 Performance (2.5"), DL320e Gen8 Special Server (2.5"), DL320e Gen8 v2 (2.5"), DL320e Gen8 v2 Base (2.5"), DL320e Gen8 v2 Performance (2.5"), DL360 Gen9 CMS (2.5"), DL360 Gen9 Entry (2.5"), DL360p Gen8 (2.5"), DL360p Gen8 CMS (2.5"), DL360p Gen8 Performance (2.5"), DL360p Gen8 Special Server (2.5"), DL380 Gen9 (2.5"), DL380 Gen9 Base (2.5"), DL380 Gen9 Entry (2.5"), DL380 Gen9 Performance (2.5"), DL380p Gen8 Performance (2.5"), DL385p Gen8 Entry (2.5"), DL385p Gen8 Storage Centric (2.5"), DL388 Gen9 (2.5"), DL388 Gen9 Base (2.5"), DL388p Gen8 (2.5"), DL388p Gen8 Base (2.5"), DL560 Gen8 (2.5"), DL560 Gen8 Base (2.5"), DL560 Gen8 Entry (2.5"), DL560 Gen8 Performance (2.5"), DL560 Gen9 (2.5"), DL560 Gen9 Base (2.5"), DL560 Gen9 Entry (2.5"), DL560 Gen9 Performance (2.5"), DL580 Gen8 (2.5"), DL580 Gen8 Base (2.5"), DL580 Gen8 High Performance (2.5"), DL580 Gen9 (2.5"), DL580 Gen9 Database (2.5"), DL580 Gen9 SAP HANA Scale-out Base Configuration (2.5"), DL580 Gen9 SAP HANA Scale-up Base Configuration (2.5"), ML110 Gen9 (2.5"), ML110 Gen9 Base (2.5"), ML110 Gen9 Entry (2.5"), ML30 Gen9 (2.5"), ML30 Gen9 Base (2.5"), ML30 Gen9 Performance (2.5"), ML350 Gen9 (2.5"), ML350 Gen9 Base (2.5"), ML350 Gen9 Entry (2.5"), ML350 Gen9 Performance (2.5"), ML350p Gen8 (2.5"), ML350p Gen8 Special Server (2.5"), WS460c Gen9 Graphics (2.5"), WS460c Gen9 Graphics Expansion (2.5"), XL170r Gen9 (2.5"), XL190r Gen9 (2.5"), XL230a Gen9 Compute Tray (2.5"), XL230a Gen9 Compute Tray (12G) (2.5"), XL230a Gen9 Compute Tray (6G) (2.5"), XL250a Gen9 Accelerator Tray (2.5")
