Product
Brand
HPE 500GB NON HOT-PLUG 7.2K RPM SA
Quicklinx: 57STWS00 Mfr#: 458941-B21
Do you have non-mission critical applications that require economical high capacity and reliability hard disk drives? HPE SATA Hard Drives are built for reliability and larger capacity needs for today's non-mission critical server applications and storage environments. These high-capacity drives provide the lowest $/GB, and the best price advantage for non-mission critical applications with low workloads of 40% or less. HPE SATA Hard Drives are available in both Large Form Factor (LFF) (3.5-inch) and Small Form Factor (SFF) (2.5-inch) and ship with a standard one-year warranty. All HPE hard drives pass a rigorous qualification process, which certify that every HPE drive is proven to perform in your HPE ProLiant Server environments. Before final certification, all HPE SATA Hard Drives are optimized for compatibility and functionality, including support of SMART and HPE Systems Insight Manager.
HPE Midline - hard drive - 500 GB - SATA 3Gb/s
Hard drive - internal
500 GB
3.5" x 1/3H
SATA 3Gb/s
Data Transfer Rate
300 MBps
Spindle Speed
7200 rpm
1 year warranty
ProLiant DL120 G5 (3.5"), DL120 G6 (3.5"), DL160 G5 (3.5"), DL160 G5p (3.5"), DL160 G6 (3.5"), DL160 G6 Special Server (3.5"), DL160se G6 (3.5"), DL165 G5 (3.5"), DL165 G5 Special Server (3.5"), DL165 G6 (3.5"), DL165 G7 (3.5"), DL165 G7 Base (3.5"), DL165 G7 Entry, MicroServer (3.5"), ML10 Entry (3.5"), ML110 G5 (3.5"), ML110 G6, ML110 G7 (3.5"), ML110 G7 Base (3.5"), ML110 G7 Entry (3.5"), ML115 G5 (3.5"), ML115 G5 Special Server, ML150 G5 (3.5"), ML150 G6 (3.5"), ML150 G6 Entry (3.5"), ML330 G6 (3.5"), ML330 G6 Entry (3.5")
500 GB
3.5" x 1/3H
SATA 3Gb/s
Performance
Drive Transfer Rate
300 MBps (external)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 3 Gb/s
Compatible Bay
3.5" x 1/3H
Limited warranty - parts and labour - 1 year
HPE ProLiant DL120 G5 (3.5"), DL120 G6 (3.5"), DL160 G5 (3.5"), DL160 G5p (3.5"), DL160 G6 (3.5"), DL160 G6 Special Server (3.5"), DL160se G6 (3.5"), DL165 G5 (3.5"), DL165 G5 Special Server (3.5"), DL165 G6 (3.5"), DL165 G7 (3.5"), DL165 G7 Base (3.5"), DL165 G7 Entry, MicroServer (3.5"), ML10 Entry (3.5"), ML110 G5 (3.5"), ML110 G6, ML110 G7 (3.5"), ML110 G7 Base (3.5"), ML110 G7 Entry (3.5"), ML115 G5 (3.5"), ML115 G5 Special Server, ML150 G5 (3.5"), ML150 G6 (3.5"), ML150 G6 Entry (3.5"), ML330 G6 (3.5"), ML330 G6 Entry (3.5")
