Do you have non mission-critical applications that require economical high capacity and reliability hard disk drives? HPE Server SATA Hard Drives are built for reliability and larger capacity needs for today's non mission-critical server applications and storage environments. These high-capacity drives provide the lowest $/GB, and the best price advantage for non-mission critical applications with low workloads of 40% or less. HPE Server SATA Hard Drives are available in both 3.5-inch Large Form Factor (LFF) and 2.5-inch Small Form Factor (SFF) and ship with a standard one-year warranty. All Hewlett Packard Enterprise hard drives pass a rigorous qualification process, which certify that every drive is proven to perform in your HPE ProLiant Server environments. Before final certification, all HPE Server SATA Hard Drives are optimized for compatibility and functionality, including support of SMART and HPE Systems Insight Manager.
- HPE Entry - hard drive - 500 GB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 500 GB
- Form Factor
- 3.5" LFF
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Spindle Speed
- 7200 rpm
- Native Command Queuing (NCQ)
- 7.22 cm x 13.66 cm x 1.6 cm
- 1-year warranty
- Designed For
- ProLiant DL20 Gen9 (3.5"), DL20 Gen9 Entry (3.5"), DL20 Gen9 Performance (3.5"), MicroServer Gen10 (3.5"), MicroServer Gen10 Entry (3.5" LFF), MicroServer Gen10 Performance (3.5" LFF), MicroServer Gen10 Stockage Collaboration (3.5"), MicroServer Gen8 Performance (3.5" LFF), ML10 Gen9 (3.5"), ML10 Gen9 Entry (3.5"), ML10 Gen9 Performance (3.5"), ML10 v2 (3.5"), ML10 v2 Base (3.5"), ML10 v2 Entry (3.5"), ML10 v2 Performance (3.5"), ML350 Gen10 (3.5"), ML350 Gen10 Base (3.5"), ML350 Gen10 Entry (3.5"), ML350 Gen10 High Performance (3.5"), ML350 Gen10 Performance (3.5"), ML350 Gen10 SMB (3.5"), ML350 Gen10 Solution (3.5"), ML350 Gen10 Special Server (3.5"), ML350 Gen10 Sub-Entry (3.5")
- Capacity
- 500 GB
- Form Factor
- 3.5" LFF
- Interface
- SATA 6Gb/s
- Bytes per Sector
- 512
- 7.22 cm
- 13.66 cm
- 1.6 cm
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Seek Time
- 8.5 ms (average) / 18 ms (max)
- Track-to-Track Seek Time
- 1 ms
- Spindle Speed
- 7200 rpm
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5" LFF
- Limited warranty - 1 year
- 5 °C
- 60 °C
- Designed For
- HPE ProLiant DL20 Gen9 (3.5"), DL20 Gen9 Entry (3.5"), DL20 Gen9 Performance (3.5"), MicroServer Gen10 (3.5"), MicroServer Gen10 Entry (3.5" LFF), MicroServer Gen10 Performance (3.5" LFF), MicroServer Gen10 Stockage Collaboration (3.5"), MicroServer Gen8 Performance (3.5" LFF), ML10 Gen9 (3.5"), ML10 Gen9 Entry (3.5"), ML10 Gen9 Performance (3.5"), ML10 v2 (3.5"), ML10 v2 Base (3.5"), ML10 v2 Entry (3.5"), ML10 v2 Performance (3.5"), ML350 Gen10 (3.5"), ML350 Gen10 Base (3.5"), ML350 Gen10 Entry (3.5"), ML350 Gen10 High Performance (3.5"), ML350 Gen10 Performance (3.5"), ML350 Gen10 SMB (3.5"), ML350 Gen10 Solution (3.5"), ML350 Gen10 Special Server (3.5"), ML350 Gen10 Sub-Entry (3.5")
