Product
HPE 500 W hot-plug power supply
Quicklinx: D3C4WS00 Mfr#: 754377-001
Power Rating: 500Watt
Hurry, only 2 left in stock!
£218.64 ex VAT
£262.36 inc VAT
HPE Hot Plug Power Supply - 80 PLUS Platinum - AC 100-240 V - 500 Watt
HPE - power supply - hot-plug / redundant - 500 Watt
Power supply - hot-plug / redundant - plug-in module
Specification Compliance
Flex Slot
80 PLUS Certification
80 PLUS Platinum
Input Voltage
AC 100-240 V
Power Capacity
500 Watt
ProLiant DL360 Gen9 (500 Watt), DL360 Gen9 Base (500 Watt), DL360 Gen9 CMS (500 Watt), DL360 Gen9 Entry (500 Watt), DL360 Gen9 Performance (500 Watt), DL380 Gen9 (500 Watt), DL380 Gen9 Base (500 Watt), DL380 Gen9 Entry (500 Watt), DL380 Gen9 Performance (500 Watt)
Flex Slot
Input Voltage
AC 100-240 V
Frequency Required
50/60 Hz
Power Capacity
500 Watt
Efficiency
94%
80 PLUS Platinum
HPE ProLiant DL360 Gen9 (500 Watt), DL360 Gen9 Base (500 Watt), DL360 Gen9 CMS (500 Watt), DL360 Gen9 Entry (500 Watt), DL360 Gen9 Performance (500 Watt), DL380 Gen9 (500 Watt), DL380 Gen9 Base (500 Watt), DL380 Gen9 Entry (500 Watt), DL380 Gen9 Performance (500 Watt)
Brand: HPE
Price Range Ex VAT: 150 - 300
