HP 4U 8 Small Form Factor Hot Plug Hard Drive Cage Kit
1.36 kg
Minimum dimensions (W x D x H)
19.58 x 23.8 x 21.29 cm
Designed for ProLiant ML310e Gen8, ML310e Gen8 base, ML310e Gen8 entry, ML310e Gen8 performance
- Hard drive size: 63.5 mm
- Number of hard drives supported: 8
- Rack capacity: 4U
- Device type: storage drive cage
- HPE - storage drive cage
- Storage drive cage
- Expansion Bays
- 8 x hot-swap - 2.5" SFF
- Hard Drive Form Factor Compatibility
- 2.5"
- 1.36 kg
- Designed For
- ProLiant ML310e Gen8 (2.5"), ML310e Gen8 Base (2.5"), ML310e Gen8 Entry (2.5"), ML310e Gen8 Performance (2.5")
- 2.5"
Storage Controller
- Processor
- No CPU
- Bays
- 1.36 kg
- Designed For
- HPE ProLiant ML310e Gen8 (2.5"), ML310e Gen8 Base (2.5"), ML310e Gen8 Entry (2.5"), ML310e Gen8 Performance (2.5")
