Product
Brand
HPE 4TB SATA Hard Drive 7200RPM
Quicklinx: C26RWS00 Mfr#: 693720-001
HP 4TB 3.5-inch (LFF) Serial ATA (SATA) 6G 7.2K Hot-Plug Midline (MDL) Hard Drive in G8 G9 (Gen8 Gen9) SmartDrive Carrier (SC) (as pictured) Genuine HP serial number and firmware.
HP SATA hard drives are designed for the reliability and larger capacities demanded by today's entry server and external storage environments. HP SATA Midline hard drives are designed with economical reliability and performance for external storage backups and archival applications. Midline SATA hard drives provide the best price advantage for non-mission critical applications with low workloads of 40% or less. HP SATA hard drives are available in both Large Form Factor (LFF) (3.5-inch) and Small Form Factor (SFF) (2.5-inch).
HPE Midline - hard drive - 4 TB - SATA 6Gb/s
Hard drive - hot-swap
4 TB
3.5" LFF
SATA 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
7200 rpm
Bundled with
HP SmartDrive carrier
ProLiant ML350p Gen8 (3.5"), ML350p Gen8 Base (3.5"), ML350p Gen8 Entry (3.5"), ML350p Gen8 Performance (3.5"), ML350p Gen8 Special Server (3.5")
4 TB
3.5" LFF
SATA 6Gb/s
Bundled with
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" LFF
HPE ProLiant ML350p Gen8 (3.5"), ML350p Gen8 Base (3.5"), ML350p Gen8 Entry (3.5"), ML350p Gen8 Performance (3.5"), ML350p Gen8 Special Server (3.5")
