Your basket is empty
HPE 4TB 6G SATA 7.2K 3.5IN LFF
Quicklinx: 8X20WS00 Mfr#: 693687-B21
Form Factor: 3.5" LFF
Type: Hard drive
Interface Type: Serial ATA-300
Capacity: 4TB
Spin Speed (rpm): 7200rpm
£196.76 ex VAT
£236.11 inc VAT
Do you have non-mission critical applications that require economical high capacity and reliability hard disk drives? HPE SATA Hard Drives are built for reliability and larger capacity needs for today's non-mission critical server applications and storage environments. These high-capacity drives provide the lowest $/GB, and the best price advantage for non-mission critical applications with low workloads of 40% or less. HPE SATA Hard Drives are available in both Large Form Factor (LFF) (3.5-inch) and Small Form Factor (SFF) (2.5-inch) and ship with a standard one-year warranty. All HPE hard drives pass a rigorous qualification process, which certify that every HPE drive is proven to perform in your HPE ProLiant Server environments. Before final certification, all HPE SATA Hard Drives are optimized for compatibility and functionality, including support of SMART and HPE Systems Insight Manager.
HPE Midline - hard drive - 4 TB - SATA 6Gb/s
Hard drive - hot-swap
4 TB
3.5" LFF
SATA 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
7200 rpm
Native Command Queuing (NCQ)
105.8 mm x 170 mm x 26.8 mm
1 year warranty
Bundled with
HP SmartDrive carrier
ProLiant DL180 Gen9, DL20 Gen9, DL320e Gen8, DL360 Gen9, DL380 Gen9, DL385p Gen8, DL80 Gen9, ML110 Gen9, ML30 Gen9, ML310e Gen8, ML350 Gen9, ML350e Gen8, ML350p Gen8, SL4545 G7
4 TB
3.5" LFF
SATA 6Gb/s
Bytes per Sector
512
105.8 mm
170 mm
26.8 mm
Bundled with
Performance
Drive Transfer Rate
600 MBps (external)
Seek Time
8.5 ms (average) / 16.2 ms (max)
Track-to-Track Seek Time
0.8 ms
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" LFF
1 year warranty
Limited warranty - 1 year
10 °C
35 °C
HPE ProLiant DL180 Gen9 (3.5"), DL180 Gen9 Base (3.5"), DL180 Gen9 Entry (3.5"), DL180 Gen9 Storage (3.5"), DL20 Gen9 (3.5"), DL20 Gen9 Entry (3.5"), DL20 Gen9 Performance (3.5"), DL320e Gen8 (3.5"), DL320e Gen8 Base (3.5"), DL320e Gen8 Entry (3.5"), DL320e Gen8 Performance (3.5"), DL360 Gen9 CMS (3.5"), DL380 Gen9 (3.5"), DL380 Gen9 Base (3.5"), DL380 Gen9 Entry (3.5"), DL380 Gen9 Performance (3.5"), DL385p Gen8 (3.5"), DL385p Gen8 Dedicated Workload (3.5"), DL385p Gen8 Entry (3.5"), DL385p Gen8 Maximized Consolidation (3.5"), DL385p Gen8 Storage (3.5"), DL80 Gen9 (3.5"), DL80 Gen9 Entry (3.5"), ML110 Gen9 (3.5"), ML110 Gen9 Base (3.5"), ML110 Gen9 Entry (3.5"), ML30 Gen9 (3.5"), ML30 Gen9 Base (3.5"), ML30 Gen9 Performance (3.5"), ML310e Gen8 (3.5"), ML310e Gen8 Base (3.5"), ML310e Gen8 Entry (3.5"), ML310e Gen8 Performance (3.5"), ML310e Gen8 v2 Base (3.5"), ML350 Gen9 (3.5"), ML350 Gen9 Base (3.5"), ML350 Gen9 Entry (3.5"), ML350 Gen9 Performance (3.5"), ML350e Gen8 v2 (3.5"), ML350e Gen8 v2 Base (3.5"), ML350p Gen8 Special Server (3.5"), SL4545 G7 (3.5")
HPE 4TB 6G SATA 7.2K 3.5IN LFF Bundle deal on HPE 4TB 6G SATA 7.2K 3.5IN LFF
£217.92
saving £14.10
Cables
Including:
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £5.70 | in stock
£199.61
saving £2.85
Type: Hard drive
Capacity: 4TB
Brand: HPE
Price Range Ex VAT: 150 - 300
