Do you have non mission-critical applications that require economical high capacity and reliability hard disk drives? HPE Server SATA Hard Drives are built for reliability and larger capacity needs for today's non mission-critical server applications and storage environments. These high-capacity drives provide the lowest $/GB, and the best price advantage for non-mission critical applications with low workloads of 40% or less.
HPE Server SATA Hard Drives are available in both 3.5-inch Large Form Factor (LFF) and 2.5-inch Small Form Factor (SFF) and ship with a standard one-year warranty. All Hewlett Packard Enterprise hard drives pass a rigorous qualification process, which certify that every drive is proven to perform in your HPE ProLiant Server environments.
Before final certification, all HPE Server SATA Hard Drives are optimized for compatibility and functionality, including support of SMART and HPE Systems Insight Manager.
What's new
Up to 10 TB SATA 7.2K LFF 512e Helium Hard Disk Drives
Designed and Engineered to Provide Reliable and Cost Efficient Data Storage
- The HPE Server SATA Hard Drives increase reliability and lower start-up costs without sacrificing reliability with non-mission critical hard drives at the lowest $/GB.
- Both cost and capacity optimized solutions provide up to 10 TB of storage in a single device. Available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) that are available in a wide variety of capacity points.
- Rotational Vibration Sensors deliver enhanced rotational vibration tolerance that provides enterprise class reliability in midline drives.
- 6 Gb/sec data transfer rate supporting existing servers.
Designed and Engineered to Provide High Capacity and Reliable Secure Storage
HPE Server Midline Hard Drives are ideal for bulk data storage, cloud and web infrastructure environments.Broad portfolio of optimized solutions provide up to 10 TB of storage, and growing in a single device.Rotational Vibration Sensors deliver enhanced rotational vibration tolerance that provides enterprise class reliability in midline drives.Available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) in a wide variety of capacity points.Prevent unauthorized access to your data with HPE Digitally Signed Firmware. It provides the security and assurance that drive firmware comes from a trusted source and protects against malicious attacks. -
Support Entry/SMB servers with value priced drives
HPE Server Midline Hard Drives have lower start-up costs without sacrificing reliability at the lowest $/GB.Non-mission critical hard drives at the lowest $/GB.6 Gb/sec data transfer rate to support existing servers.
- HPE Performance - hard drive - 4 TB - SATA 6Gb/s
- Hard drive - hot-swap
- Capacity
- 4 TB
- Form Factor
- 3.5" LFF
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Spindle Speed
- 7200 rpm
- Native Command Queuing (NCQ), advanced format 512e
- 105.8 mm x 170 mm x 26.8 mm
- 1-year warranty
- Bundled with
- HP SmartDrive carrier
- Designed For
- ProLiant DL120 Gen9, DL160 Gen8, DL180 Gen9, DL20 Gen9, DL320e Gen8, DL360 Gen9, DL380p Gen8, DL385p Gen8, DL388 Gen9, DL388p Gen8, DL80 Gen9, ML150 Gen9, ML350 Gen9; StoreEasy 1650
- Capacity
- 4 TB
- Form Factor
- 3.5" LFF
- Interface
- SATA 6Gb/s
- Bytes per Sector
- 512
- 105.8 mm
- 170 mm
- 26.8 mm
- Bundled with
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Seek Time
- 7.6 ms (average) / 15 ms (max)
- Track-to-Track Seek Time
- 0.25 ms
- Spindle Speed
- 7200 rpm
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 3.5" LFF
- Limited warranty - 1 year
- 10 °C
- 35 °C
- Designed For
- HPE ProLiant DL120 Gen9 (3.5"), DL120 Gen9 Entry (3.5"), DL160 Gen8 (3.5"), DL160 Gen8 Base (3.5"), DL160 Gen8 Entry (3.5"), DL160 Gen8 Performance (3.5"), DL180 Gen9 (3.5"), DL180 Gen9 Base (3.5"), DL180 Gen9 Entry (3.5"), DL180 Gen9 Storage (3.5"), DL20 Gen9 (3.5"), DL20 Gen9 Entry (3.5"), DL20 Gen9 Performance (3.5"), DL320e Gen8 (3.5"), DL320e Gen8 Base (3.5"), DL320e Gen8 Entry (3.5"), DL320e Gen8 Performance (3.5"), DL320e Gen8 Special Server (3.5"), DL320e Gen8 v2 (3.5"), DL320e Gen8 v2 Base (3.5"), DL320e Gen8 v2 Entry (3.5"), DL320e Gen8 v2 Performance (3.5"), DL360 Gen9 (3.5"), DL360 Gen9 Base (3.5"), DL360 Gen9 CMS (3.5"), DL360 Gen9 Entry (3.5"), DL360 Gen9 High Performance (3.5"), DL360 Gen9 Performance (3.5"), DL380p Gen8 (3.5"), DL380p Gen8 Base (3.5"), DL380p Gen8 Entry (3.5"), DL380p Gen8 High Performance (3.5"), DL380p Gen8 Performance (3.5"), DL380p Gen8 Special (3.5"), DL385p Gen8 (3.5"), DL385p Gen8 Dedicated Workload (3.5"), DL385p Gen8 Entry (3.5"), DL385p Gen8 Maximized Consolidation (3.5"), DL385p Gen8 Storage (3.5"), DL385p Gen8 Storage Centric (3.5"), DL388 Gen9 (3.5"), DL388 Gen9 Base (3.5"), DL388p Gen8 Base (3.5"), DL80 Gen9 (3.5"), DL80 Gen9 Entry (3.5"), ML150 Gen9 (3.5"), ML150 Gen9 Base (3.5"), ML150 Gen9 Entry (3.5"), ML150 Gen9 Performance (3.5"), ML350 Gen9 (3.5"), ML350 Gen9 Base (3.5"), ML350 Gen9 Entry (3.5"), ML350 Gen9 Performance (3.5") , HPE StoreEasy 1650
