Is finding reliable DRAM memory for your HP ProLiant Gen8 Server series in your data center a major challenge? When you choose HP SmartMemory you get the same high quality, reliability, and confidence that come with your HP ProLiant Gen8 Server series. DRAM quality and reliability are more important now than ever. Industry trends such as server virtualization, cloud computing, the use of large database applications, and high-performance computing have all created demand for higher capacity memory with greater reliability and uptime. HP SmartMemory unlocks certain features available only with HP Qualified Server memory. HP SmartMemory enables ProLiant Gen8 Servers to reliably identify and verify whether installed memory has passed the rigorous HP qualification and testing processes. And because the memory is authenticated, you can enable extended memory performance features through the system ROM.
High Performance
HPE DDR3 SmartMemory performs to industry-defined specifications.HPE DDR3 SmartMemory has been tested and performance-tuned specifically for HPE ProLiant Server series, which ensures that HPE server memory is optimized for every HPE server.HPE DDR3 SmartMemory enables extended memory performance features through the system ROM. -
High Reliability
HPE DDR3 SmartMemory is made of the highest quality materials, reducing issues that affect signal integrity and increasing system reliability. -
Improved Efficiency
HPE DDR3 SmartMemory supports HPE servers at a lower price point.
- HPE - DDR3 - module - 4 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - unbuffered
- Product Type
- Memory module
- Capacity
- 4 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 1333 MHz (PC3-10600)
- Latency Timings
- CL9
- Dual rank, unbuffered
- Voltage
- 1.5 V
- OEM Manufacturer Equivalent Part Number
- HP 593923-B21, HP 595102-001
- Designed For
- ProLiant BL465c G7, DL385 G7 HE, SL165s G7, SL165z G7, SL335s G7 1U Left Tray Node Server, SL335s G7 1U Right Tray Node Server
- Capacity
- 4 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- CL9
- ECC
- Chips Organization
- X8
- Voltage
- 1.5 V
- Compatible Slots
- 1 x memory - DIMM 240-pin
- Designed For
- HPE ProLiant BL465c G7, DL385 G7 HE, SL165s G7, SL165z G7, SL335s G7 1U Left Tray Node Server, SL335s G7 1U Right Tray Node Server
