HPE 4GB KIT 1RX4 PC3-10600R-9 RDIM
Quicklinx: 71D9WS00 Mfr#: 593911-B21
Is finding reliable DRAM memory for your HP ProLiant Gen8 Server series in your data center a major challenge? When you choose HP SmartMemory you get the same high quality, reliability, and confidence that come with your HP ProLiant Gen8 Server series. DRAM quality and reliability are more important now than ever. Industry trends such as server virtualization, cloud computing, the use of large database applications, and high-performance computing have all created demand for higher capacity memory with greater reliability and uptime. HP SmartMemory unlocks certain features available only with HP Qualified Server memory. HP SmartMemory enables ProLiant Gen8 Servers to reliably identify and verify whether installed memory has passed the rigorous HP qualification and testing processes. And because the memory is authenticated, you can enable extended memory performance features through the system ROM.
  • High Performance
    HPE DDR3 SmartMemory performs to industry-defined specifications.HPE DDR3 SmartMemory has been tested and performance-tuned specifically for HPE ProLiant Server series, which ensures that HPE server memory is optimized for every HPE server.HPE DDR3 SmartMemory enables extended memory performance features through the system ROM.
  • High Reliability
    HPE DDR3 SmartMemory is made of the highest quality materials, reducing issues that affect signal integrity and increasing system reliability.
  • Improved Efficiency
    HPE DDR3 SmartMemory supports HPE servers at a lower price point.
HPE - DDR3 - module - 4 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - registered
Memory module
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9
Single rank, registered
ProLiant BL465c G7, BL685c G7, DL165 G7, DL165 G7 Base, DL165 G7 Entry, DL165 G7 Performance, DL165 G7 Special Server, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 Performance, DL585 G7, DL585 G7 Base, SL165s G7, SL165z G7
4 GB
Upgrade Type
System specific
DRAM memory module
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9
ECC
Chips Organization
X4
Compatible Slots
1 x memory - DIMM 240-pin
HPE ProLiant BL465c G7, BL685c G7, DL165 G7, DL165 G7 Base, DL165 G7 Entry, DL165 G7 Performance, DL165 G7 Special Server, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 Performance, DL585 G7, DL585 G7 Base, SL165s G7, SL165z G7
