HPE 4GB (1x4GB) DDR3-1600 non-ECC RAM
Quicklinx: 8CV6WS00 Mfr#: B1S53AA
4GB (1x4GB configuration) of DDR3-1600 Non-ECC RAM DIMMs. Boost the capabilities of your HP Workstation and keep it performing reliably with HP memory. Upgrading your memory is a cost-effective way to improve system performance when insufficient memory and hard drive paging is slowing your applications down.
HP - DDR3 - module - 4 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered
Memory module
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Unbuffered
HP B1S53AA
Workstation Z1, Z220, Z230
4 GB
Upgrade Type
System specific
HP B1S53AA
DRAM memory module
DDR3 SDRAM
DIMM 240-pin
Speed
Non-ECC
Unbuffered
Compatible Slots
1 x memory - DIMM 240-pin
HP Workstation Z1, Z220, Z230
