Your basket is empty
HPE 32GB 4RX4 PC3L-10600L-9 KIT
Quicklinx: BH9KWS00 Mfr#: 647885-B21
Type: DDR3L SDRAM
Capacity: 32GB
Connection: LRDIMM 240-pin
Speed: 1333MHz
Registered/Buffered: Load-Reduced
£268.04 ex VAT
£321.64 inc VAT
Is finding reliable DRAM memory for your HP ProLiant Gen8 Server series in your data center a major challenge? When you choose HP SmartMemory you get the same high quality, reliability, and confidence that come with your HP ProLiant Gen8 Server series. DRAM quality and reliability are more important now than ever. Industry trends such as server virtualization, cloud computing, the use of large database applications, and high-performance computing have all created demand for higher capacity memory with greater reliability and uptime. HP SmartMemory unlocks certain features available only with HP Qualified Server memory. HP SmartMemory enables ProLiant Gen8 Servers to reliably identify and verify whether installed memory has passed the rigorous HP qualification and testing processes. And because the memory is authenticated, you can enable extended memory performance features through the system ROM.
HPE Low Power kit - DDR3L - 32 GB - LRDIMM 240-pin
RAM memory
32 GB
Memory Type
DDR3L SDRAM - LRDIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1333 MHz (PC3L-10600)
Latency Timings
CL9
Quad rank, Low Voltage, Load-Reduced
Voltage
1.35 V
HP 647885-B21
ProLiant BL465c Gen8, DL385p Gen8, DL385p Gen8 Dedicated Workload, DL385p Gen8 Entry, DL385p Gen8 Maximized Consolidation, DL385p Gen8 Storage
32 GB
Upgrade Type
System specific
HP 647885-B21
DRAM
DDR3L SDRAM
LRDIMM 240-pin
Speed
Latency Timings
CL9
ECC
Chips Organization
X4
Voltage
1.35 V
WEEE
HPE ProLiant BL465c Gen8, DL385p Gen8, DL385p Gen8 Dedicated Workload, DL385p Gen8 Entry, DL385p Gen8 Maximized Consolidation, DL385p Gen8 Storage
HPE 32GB 4RX4 PC3L-10600L-9 KIT Bundle deal on HPE 32GB 4RX4 PC3L-10600L-9 KIT
£289.23
saving £14.13
Type: DDR3L SDRAM
Capacity: 32GB
Speed: 1333MHz
Brand: HPE
Price Range Ex VAT: 150 - 300
