HPE 300GB SAS HARD DRIVE 15K RPM 2.5"
Quicklinx: CB27WS00 Mfr#: 759546-001
The HP 759546-001 model internal hard drive has a 2.5 inch form factor and a 12Gb/s external data transfer rate. It has a spindle speed of up to 15000 rpm and a 300GB capacity.
This SFF drive uses a 12Gb/s SAS (serial attached SCSI) interface and comes enclosed in a hot-swap tray along with a 1 year warranty.
- Form Factor: 2.5 inch
- Capacity: 300GB
- Speed: 15k RPM
- Interface: SAS
- Manufacturer: HP
- Type: HDD
HPE Enterprise - hard drive - 300 GB - SAS 12Gb/s
Hard drive - hot-swap
300 GB
2.5" SFF
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Spindle Speed
15000 rpm
3-year warranty
Bundled with
HP SmartDrive carrier
ProLiant ML350 Gen9 (2.5"), ML350 Gen9 Base (2.5"), ML350 Gen9 Entry (2.5"), ML350 Gen9 Performance (2.5")
300 GB
2.5" SFF
SAS 12Gb/s
Bundled with
Performance
Drive Transfer Rate
1.2 GBps (external)
Spindle Speed
15000 rpm
Expansion & Connectivity
1 x SAS 12 Gb/s
Compatible Bay
2.5" SFF
Limited warranty - 3 years
HPE ProLiant ML350 Gen9 (2.5"), ML350 Gen9 Base (2.5"), ML350 Gen9 Entry (2.5"), ML350 Gen9 Performance (2.5")
