HPE 300GB SAS 600Mbps 15000rpm Dual Port Hot-Swap HDD
Quicklinx: 7R72WS00 Mfr#: 516824-B21
Do your servers need high-performance SAS disk drives for both your mission-critical and storage driven applications? HP SAS Hard Drives for enterprise and midline applications deliver high-performance solutions for hosting high transaction based applications. They are available in HP Smart Carrier, HP Standard Hot Plug Carrier and HP Non-hot Plug Carrier. HP SAS Hard Drives are available in a 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) and come in a variety of capacity points to meet a wide range of requirements supporting enterprise and midline applications. The SAS interface was specifically engineered to deliver high availability where enterprise-class data storage where performance, reliability and data integrity are crucial.
  • Performance and Reliability for Multiple Application Environments
    HPE Server SAS Hard Drives deliver high reliability for mission-critical applications.Robust SAS interface (dual port, full duplex) for increased performance.HPE Smart Carrier for HPE ProLiant Servers (both Gen8 and Gen9 are supported). They maintain backward compatibility with existing standard hot-plug carriers to provide support for HPE ProLiant G7 and earlier servers and server storage enclosures.They are ideal for transaction processing, database applications, analytics, high-performance computing and business applications.The 512e Advance Format Drive is ideal for 4KiB aligned operating systems and applications. They also support legacy 512K native applications.
HPE Dual Port Enterprise - hard drive - 300 GB - SAS 6Gb/s
Hard drive - internal
300 GB
3.5" x 1/3H
SAS 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
15000 rpm
11.7 cm x 18.9 cm x 2.6 cm
3-year warranty
ProLiant DL160 G6, DL160 G6 Special Server, ML110 G6, ML110 G6 Special Server, ML110 G7 (3.5" LFF, 3.5" LFF, 3.5" LFF, 3.5" LFF), ML150 G6, ML330 G6 (3.5")
300 GB
3.5" x 1/3H
SAS 6Gb/s
11.7 cm
18.9 cm
2.6 cm
Performance
Drive Transfer Rate
600 MBps (external)
Seek Time
3.5 ms (average) / 6.8 ms (max)
Track-to-Track Seek Time
0.2 ms
Spindle Speed
15000 rpm
Expansion & Connectivity
2 x SAS 6Gb/s
Compatible Bay
3.5" x 1/3H
Limited warranty - 3 years
10 °C
35 °C
HPE ProLiant DL160 G6, DL160 G6 Special Server, ML110 G6, ML110 G6 Special Server, ML110 G7 (3.5" LFF, 3.5" LFF, 3.5" LFF, 3.5" LFF), ML150 G6, ML330 G6 (3.5")
