Product
Brand
HPE 300GB 12G 10k rpm HPL SAS SFF (2.5in) Smart Carrier
Quicklinx: C63BWS00 Mfr#: 785067-B21
Do your servers need high-performance SAS disk drives for both your mission-critical and storage driven applications? HPE Server SAS Hard Drives for enterprise and midline applications deliver high-performance solutions for hosting high transaction based applications. They are available in HPE Smart Carrier, HPE Standard Hot Plug Carrier and HPE Non-hot Plug Carrier. HPE Server SAS Hard Drives are available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) and come in a variety of capacity points to meet a wide range of requirements supporting enterprise and midline applications. The SAS interface was specifically engineered to deliver high availability where enterprise-class data storage, performance, reliability and data integrity are crucial.
HPE Enterprise - hard drive - 300 GB - SAS 12Gb/s
Hard drive - hot-swap
300 GB
2.5"
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Spindle Speed
10000 rpm
Bundled with
HP SmartDrive carrier
ProLiant BL460c Gen10, BL465c Gen8, BL660c Gen9, DL120 Gen9, DL180 Gen9, DL20 Gen9, DL320e Gen8, DL388 Gen9, DL560 Gen9, DL580 Gen9, ML110 Gen9, ML310e Gen8, ML350e Gen8, XL230a Gen9, XL230k Gen10, XL250a Gen9; Synergy 480 Gen10, 660 Gen10
300 GB
2.5"
SAS 12Gb/s
Bundled with
Performance
Drive Transfer Rate
1.2 GBps (external)
Spindle Speed
10000 rpm
Expansion & Connectivity
1 x SAS 12 Gb/s
Compatible Bay
2.5"
HPE ProLiant BL460c Gen10 (2.5"), BL465c Gen8 (2.5"), BL660c Gen9 (2.5"), DL120 Gen9 (2.5"), DL120 Gen9 Entry (2.5"), DL180 Gen9 (2.5"), DL180 Gen9 Base (2.5"), DL180 Gen9 Entry (2.5"), DL180 Gen9 Storage (2.5"), DL20 Gen9 (2.5"), DL20 Gen9 Entry (2.5"), DL20 Gen9 Performance (2.5"), DL320e Gen8 (2.5"), DL320e Gen8 Base (2.5"), DL320e Gen8 Entry (2.5"), DL320e Gen8 Performance (2.5"), DL320e Gen8 Special Server (2.5"), DL320e Gen8 v2 (2.5"), DL320e Gen8 v2 Base (2.5"), DL320e Gen8 v2 Entry (2.5"), DL320e Gen8 v2 Performance (2.5"), DL388 Gen9 (2.5"), DL388 Gen9 Base (2.5"), DL560 Gen9 (2.5"), DL560 Gen9 Base (2.5"), DL560 Gen9 Entry (2.5"), DL560 Gen9 Performance (2.5"), DL580 Gen9 (2.5"), DL580 Gen9 Database (2.5"), DL580 Gen9 SAP HANA Scale-up Base Configuration (2.5"), ML110 Gen9 (2.5"), ML110 Gen9 Base (2.5"), ML110 Gen9 Entry (2.5"), ML310e Gen8 (2.5"), ML310e Gen8 Base (2.5"), ML310e Gen8 Entry (2.5"), ML310e Gen8 Performance (2.5"), ML310e Gen8 v2 (2.5"), ML310e Gen8 v2 Base (2.5"), ML310e Gen8 v2 Enty (2.5"), ML310e Gen8 v2 Performance (2.5"), ML350e Gen8 (2.5"), ML350e Gen8 Base (2.5"), ML350e Gen8 Entry (2.5"), ML350e Gen8 Performance (2.5"), ML350e Gen8 v2 (2.5"), ML350e Gen8 v2 Base (2.5"), ML350e Gen8 v2 Entry (2.5"), XL230a Gen9 Compute Tray (2.5"), XL230a Gen9 Compute Tray (12G) (2.5"), XL230a Gen9 Compute Tray (6G) (2.5"), XL230a Gen9 NHP Compute Tray (12G), XL230k Gen10 Compute Tray (2.5"), XL250a Gen9 Accelerator Tray (2.5") , HPE Synergy 480 Gen10 Base Compute Module (2.5"), 480 Gen10 Entry Compute Module (2.5"), 480 Gen10 Performance Compute Module (2.5"), 480 Gen10 Premium Backplane Compute Module (2.5"), 480 Gen10 Standard BackPlane Compute Module (2.5"), 480 Gen10 w/o Drives Compute Module (2.5"), 660 Gen10 Base Compute Module (2.5"), 660 Gen10 Compute Module (2.5"), 660 Gen10 Entry Compute Module (2.5"), 660 Gen10 Performance Compute Module (2.5"), 660 Gen10 Premium Compute Module (2.5")
